How to run Raspberry PI detection.py example without ui
I’m running the Rasperry PI detection net example. When i have the display connected the program works and runs smoothly as expected.
How can i run the program without using a display? Is this part of the gstreamer configuration or somewhere else ? I would basically just need the detected labels as well as the confidency value.
If you want to disable the video output you can simply replace the following code
f"fpsdisplaysink video-sink={self.video_sink} name=hailo_display sync={self.sync} text-overlay={self.options_menu.show_fps} signal-fps-measurements=true "
with
f"fakesink "
You can likely simplify the pipeline a little bit. But this is a simple change. The fakesink element will just discard the data at that point of the pipeline instead of displaying the video stream.
