How to reduce contexts and optimize model for >30 FPS
:information_source: Background
I trained a custom YOLO model for small object detection. On my NVIDIA 4060 it achieves good accuracy and fast inference, but after converting it to .HEF format, performance drops to a maximum of 14 FPS on the HAILO-8L device.
To maintain accuracy on small objects, the model relies on larger tensors with bigger spatial dimensions, which I suspect may be exceeding the HAILO memory limits.
Below is some information from the Hailo Profiler report:
And my HAILO conversion commands
:red_question_mark: Questions
  1. How can I reduce the number of contexts and push the model beyond 30 FPS?
  2. Is it possible to adapt the model to fit within a single context while keeping accuracy degradation minimal?
  3. What is the best way to troubleshoot and identify the main bottleneck causing such low performance?
Please have a look at the following post I wrote a while ago.
Hailo Community - My model runs slower than expected
Additionally, I recommend having a look at the YOLO models in the Model Zoo to compare accuracy and performance on the Hailo-8L. You may need to chose another model variant.
GitHub - Hailo Model Zoo - Hailo-8L Object Detection
You will have some additional performance degradation because of the single PCIe lane on the Raspberry Pi (see forum post mentioned above).
The Hailo Dataflow Compiler has a performance mode in which the compiler will try as hard as it can to find a solution with the highest performance. See Hailo Dataflow Compiler User Guide. This will take significantly longer time to complete. It will not be able to compile your model into a single context on Hailo-8L. Your profiler report shows 274 layers.
You can also try to compile your model for Hailo-8. That should allow you to run your model faster because you will reduce the context switch overhead by compiling to fewer contexts. However it needs a Hailo-8 device to run.
I suspect it could be the same Raspberry Pi-specific bottleneck that is also reported at:
@user1232 Your colleague @omria wanted to look into the matter, but unfortunately has not yet provided any updates on the issue.
See:
