I am trying to compile a onnx to HEF, I am using the docker AI Suite and the only parameter I am missing is the HAR file.
I am planning to Import the compiled HEF file to the raspberry pi 5 but I am doing the compiling by using my computer.
The HAR file is an intermediate format generated during the model conversion. The model conversion flow is explained in the Hailo DataFlow Compiler User Guide (login required).
There are two ways to perform the model conversion:
hailo tutorial command from the Hailo AI SW Suite to open the Tutorial section, i.e. a collection of Jupyter-Notebooks that will guide you through the conversion process, including the generation of the HAR and HEF files.
