I am using an USB camera with hailo-8L on my Raspberry Pi 5.
and I have already installed the hailo-all
and Use the demo code cloned from https://github.com/hailo-ai/hailo-rpi5-examples but I can not use my USB camera as camera feed. how can i solve this problem?
You need to check whether your USB camera support video4linux short v4l2.
You should see your camera in the /dev/ directory.
ls /dev/video*
Plug the camera in and out to see the difference in case there are many video devices.
Then you can use the v4l2-ctl tool to get further information.
v4l2-ctl -D -d /dev/video0
This should print something like this:
Driver Info:
Driver name : uvcvideo
Card type : Logitech BRIO
Bus info : usb-0000:00:14.0-1
Driver version : 5.15.149
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Media Driver Info:
Model : Logitech BRIO
Serial : ACE12345
Media version : 5.15.149
Hardware revision: 0x00000317 (791)
Interface Info:
Type : V4L Video
Entity Info:
Function : V4L2 I/O
Flags : default
Pad 0x0100000d : 0: Sink
Link 0x02000029: from remote pad 0x1000010 of entity 'Processing 3': Data, Enabled, Immutable
Try another USB camera if you do not get this.
I am having the same issue.
I can see the driver info described above, but I’am getting an ERROR: *** no cameras available *** when running rpicam-apps commands. My Logitech 925e camera works fine with Cheese app.
Is Hailo-8L using the libcamera library only? Libcamera does not seem to work with USB cameras.
ok nevermind, it seems to work now on usb webcamera.
I followed the guide on github hailo-ai/hailo-rpi5-examples/
