How can I use multi chip using python code
I am trying to run the super resolution code using python code
From the example code of SR
devices = Device.scan()
with VDevice(device_ids=selected_devices) as target:
Target has default value, using only one hailo chip
Should I have to chage the pyhailort.py
class VDevice: create_params() part?
Hey @hwan136
The key is using Hailo’s Virtual Device (VDevice) API to work with multiple physical chips without modifying pyhailort.py. Here’s how to implement it:
Main Steps:
  1. Scan for available Hailo devices using Device.scan()
  2. Configure VDevice with multiple device IDs
  3. Use VDevice.create_params() for advanced control (optional)
Example Implementation:
from hailo_platform import Device, VDevice, ConfigureParams, HailoStreamInterface
# Scan and select devices
selected_devices = [devices[0], devices[1]]  # Use first two devices
# Create virtual device and run inference
    hef = HEF("your_model.hef")
    configure_params = ConfigureParams.create_from_hef(hef, interface=HailoStreamInterface.PCIe)
    with network_group.activate():
        # Your inference code here
This approach allows for efficient workload distribution across multiple Hailo chips while maintaining a simple interface for inference operations.
