I searched the documentation, and find this command " sudo systemctl enable --now hailort.service" that should be run from bash. however, it still doesn’t work, and I need to enable it in my python code
When creating the vdevice params group, one should define the “multi_process_service” parameter as True.
Here’s an example function that does it:
def create_vdevice_params():
params.multi_process_service = True
return params
