I went through the topics here facing similar problems. So i at first tried manually updating the driver packages as per 6.12.34 and got the same error., Secondly I also downgraded the kernel to version 6.6.77. Still it said the same on trying hailortcli fw-control identify. After dropping down to ver. 6.6.77 and running sudo apt install hailo-all as well as sudo apt install hailo-dkms. I am still getting the same error. Wondering if the Kit is damaged. Please help me resolve this issue. I have been following and trying to do what is mentioned in 1) Raspberry Pi 5 RT-Linux does not support Hailo hardware issues - #2 by omria , 2) Raspberry Pi Kernel Compatibility Issue - Temporary Fix - #6 by omria , and 3) 🎉 Kernel Bug Fix - Update Available! - #2
