Raspberry Pi 5 RT-Linux does not support Hailo hardware issues
Hey @g_r ,
This issue you are facing means the Hailo PCIe driver wasn’t built and installed for your new kernel.
Here’s how to fix that and get everything working again.
Hailo Driver Needs to Match Your Kernel
The HailoRT use a custom kernel driver called hailo_pci to talk over PCIe. Since it’s an out-of-tree module, it has to be compiled for your exact kernel — including:
  • Same kernel version (e.g. 6.9-rt)
  • Matching kernel headers
  • Same compiler and config
How to Rebuild the Driver for Your RT Kernel
Here’s the process, pulled from the HailoRT docs and install scripts:
  1. Install headers for your current kernel
    sudo apt install linux-headers-$(uname -r)
  2. Clone the HailoRT driver repo
    git clone --depth 1 --branch v4.20.0 https://github.com/hailo-ai/hailort-drivers.git
    cd hailort-drivers/linux/pcie
  3. Build and install the PCIe driver
    sudo make all
    sudo make install
  4. Load the driver
    sudo modprobe hailo_pci
  5. Install firmware
    cd ../../
    ./download_firmware.sh
    sudo mkdir -p /lib/firmware/hailo
    sudo mv hailo8_fw.*.bin /lib/firmware/hailo/hailo8_fw.bin
  6. Install udev rules
    sudo cp ./linux/pcie/51-hailo-udev.rules /etc/udev/rules.d/
    sudo udevadm control --reload-rules && sudo udevadm trigger
  7. Reboot and test
    sudo reboot
Once you’re back up:
Hopes this fixes the issue!
