Hello! I’m ack again, my account was deleted
I recently developed a C++ app integrated into LVGL to have my own graphic interface and show prediction on video input, actually i’m testing on walkin people “example_640.mp4” using yolov6n.hef.
It works, i see prediction but i’m not able to draw bounding boxes correctly on the source video
What could be the problem? I use GStreamer pipeline and for drawing boxes
#define FRAME_WIDTH 640
#define FRAME_HEIGHT 640
void draw_detection_overlay(uint8_t *rgb888, int width, int height) {
for (int i = 0; i < g_num_detections; ++i) {
Detection det = g_detections[i];
// Coordinate normalizzate su immagine intera
int x0 = (int)((det.x - det.w / 2.0f) * width);
int y0 = (int)((det.y - det.h / 2.0f) * height);
int x1 = (int)((det.x + det.w / 2.0f) * width);
int y1 = (int)((det.y + det.h / 2.0f) * height);
// Clamp
x0 = MY_CLAMP(x0); y0 = MY_CLAMP(y0);
if (x1 > width) x1 = width;
if (y1 > height) y1 = height;
// Colore in base alla classe
uint8_t r = 255, g = 0, b = 0;
if (det.class_id < num_class_colors) {
r = class_colors[det.class_id][0];
g = class_colors[det.class_id][1];
b = class_colors[det.class_id][2];
for (int y = y0; y < y1; ++y) {
for (int x = x0; x < x1; ++x) {
if (x == x0 || x == x1 - 1 || y == y0 || y == y1 - 1) {
int idx = (y * width + x) * 3;
rgb888[idx + 0] = r;
rgb888[idx + 1] = g;
rgb888[idx + 2] = b;
printf("Detection: class=%d box=(%.2f %.2f %.2f %.2f)\n",
det.class_id, det.x, det.y, det.w, det.h);
int gstreamer_grab_frame(lv_color_t *dst_buffer) {
GstSample *sample = gst_app_sink_pull_sample(GST_APP_SINK(appsink));
if (!sample) return -1;
GstBuffer *buffer = gst_sample_get_buffer(sample);
GstMapInfo map;
if (!gst_buffer_map(buffer, &map, GST_MAP_READ)) {
gst_sample_unref(sample);
return -1;
const uint8_t *rgb_data = map.data;
uint8_t rgb_copy[FRAME_WIDTH * FRAME_HEIGHT * 3];
memcpy(rgb_copy, rgb_data, FRAME_WIDTH * FRAME_HEIGHT * 3);
draw_detection_overlay(rgb_copy, FRAME_WIDTH, FRAME_HEIGHT);
rgb888_to_rgb565(rgb_copy, dst_buffer, FRAME_WIDTH * FRAME_HEIGHT);
gst_buffer_unmap(buffer, &map);
return 0;
int main(int argc, char **argv) {
(void)argc;
(void)argv;
lv_init();
hal_init();
if (gstreamer_init() < 0) {
return 1;
ui_init();
lv_img_set_src(ui_VideoFrame, &webcam_img);
while (1) {
pthread_mutex_lock(&buffer_mutex);
lv_color_t *dst_buffer = (current_buffer == webcam_buffer_a) ? webcam_buffer_b : webcam_buffer_a;
if (gstreamer_grab_frame(dst_buffer) == 0) {
current_buffer = dst_buffer;
webcam_img.data = (const uint8_t *)current_buffer;
lv_img_cache_invalidate_src(&webcam_img);
lv_obj_invalidate(ui_VideoFrame);
pthread_mutex_unlock(&buffer_mutex);
lv_timer_handler();
if (gstreamer_grab_frame_and_infer() != 0) {
break;
usleep(1000);
return 0;
Yes something strange in the code could be in! This is just a try, and for next step and finalizing prototype, i need to have correctly drawn bounding boxes…someone could help?
