Environment
Conversion Host
Ubuntu 22.04.3 (x86_64), Hailo DFC 3.33.0 / HailoRT 4.23.0
ONNXRuntime 1.18.0 (CPU only, no GPU)
Python 3.10.12 (venv)
Target Device
Raspberry Pi 5 + Hailo-8
Debian 12 (aarch64), HailoRT 4.20.0
Python 3.11.2, ONNXRuntime 1.23.2
Pipeline
Generated calibration .npy dataset (RGB 288×288, 220 images)
Executed hailo parser → optimize → compiler
Conversion completed successfully (no critical errors)
Compared ONNX vs HEF feature maps (L2: 512×36×36, L3: 1024×18×18) –> Shapes match perfectly, but numeric similarity is very poor — cosine < 0.6.
Question
Has anyone experienced cases where the model’s behavior (feature maps, accuracy, or numeric similarity) becomes severely distorted after the parser or optimize stage, even though the conversion completes successfully?
If so:
What were the main causes (e.g., calibration set issues, normalization mismatch, per-channel quantization, etc.)?
And how did you resolve them? (e.g., increasing calibration set size, enabling GPU calibration, adjusting preprocessing, or fine-tuning parser options)
In my case, I suspect weak calibration (only 64 samples actually used) and a possible normalization mismatch, but I’d like to know whether others have seen similar degradation and how you addressed it.
