Hi everyone
Could you share which version of hailort includes the hailortcli monitor command? I checked the changelog and the command line interface documentation but couldn’t find the information. ChatGPT mentioned that it was introduced in version 4.18.0.
Is that correct?
Thanks a lot in advance!
We had the hailortcli monitor for a while longer. You can check the documentation for older versions of our tools available in the Developer Zone Documentation archive tab.
Thank you!
I found three HailoRT Guides in the archive, starting from version 4.17.0. According to the manual, hailortcli monitor was already available, which is great since this is the version we’re already using for the PCI driver.
Thanks a lot for your help!
