Hailo monitor does work in the ubuntu user
I have a problem when I run the hailortcli monitor command knowing that I am working in the ubuntu user and the hailort_monitor environment variable is equal to 1.
when monitoring, nothing is displayed even if the application is running
Hi, if you have only one network executed you won’t notice anything, since its the only one running.
I’m currently utilizing multiple networks with the round-robin method. Interestingly, when I ran the same script on Hailo suite container , it performed admirably. However, upon executing it on Ubuntu, I encountered an issue where nothing displayed on the user monitor.
