The full log is:
**[HailoRT] [error] Firmware control has failed. Major status: 0x4003003b, Minor status: 0x401a0004**
**[HailoRT] [error] Firmware major status: CONTROL_PROTOCOL_STATUS_USER_CONFIG_EXAMINE_FAILED**
**[HailoRT] [error] Firmware minor status: FIRMWARE_CONFIGS_STATUS_USER_CONFIG_NOT_LOADED**
**[HailoRT] [error] CHECK_SUCCESS_AS_EXPECTED failed with status=HAILO_FW_CONTROL_FAILURE(18)**
**[HailoRT] [error] CHECK_EXPECTED failed with status=HAILO_FW_CONTROL_FAILURE(18) - Failed to examine user config**
**[HailoRT CLI] [error] CHECK_EXPECTED_AS_STATUS failed with status=HAILO_FW_CONTROL_FAILURE(18) - Failed reading user config from device**
**Failed to execute on device: status= HAILO_FW_CONTROL_FAILURE(18)**
But hailortcli fw-control identify
and inference on the device works fine.
Is that something I should be concerned ?
