[HailoRT] Got CPU ECC Fatal Event During Stress Test on Hailo-8L with Raspberry Pi 5
@Nadav could you please explain the error I’m facing so i can take a note on it for our future references?
The error means that the device have overheated, and as a result will start to throttle down.
The reason is probably the use of a synthetic load that is much harsher than real conditions.
@Nadav can you explain what the ECC and memory_bitmap=4096 indicate in the context of the ECC fatal event
