hailomz compile: ValueError: Tried to convert 'input' to a tensor and failed. Error: None values not supported.
I found the solution of this in this thread Problem With Model Optimization - #25 by Nadav
what you need to do is to add this line to the alls script
quantization_param([conv42, conv53, conv63], force_range_out=[0.0, 1.0])
for this do the following search this file in your docker container
add the line before nms line and save the file
in the yaml file that you are passing through argument in the compile, for example this one
hailomz compile --ckpt yolov8m.onnx --calib-path /local/shared_with_docker/licence-plate/train/images/ --yaml hailo_model_zoo/cfg/networks/yolov8m.yaml --classes 1
modify the hailo_model_zoo/cfg/networks/yolov8m.yaml in your docker container
and change this
paths:
  network_path:
  - models_files/ObjectDetection/Detection-COCO/yolo/yolov8m/2023-02-02/yolov8m.onnx
  alls_script: yolov8m.alls
  url: https://hailo-model-zoo.s3.eu-west-2.amazonaws.com/ObjectDetection/Detection-COCO/yolo/yolov8m/2023-02-02/yolov8m.zip
alls_script: /the/path/to/the/file/that/you/changed/previusly
and re run the hailomz compile
you can find more information in the post shared.
