Thank you for your Reply.
Unfortunately it doesn’t look like that … Or, even if it would, it doesn’t seem to make a Difference
As I said, this is what appears in dmesg, even though I forced pcie_aspm=force:
[ 0.000000] Command line: BOOT_IMAGE=/vmlinuz-6.8.12-6-pve root=ZFS=/ROOT/debian ro "acpi_osi=Windows 2006" systemd.unified_cgroup_hierarchy=1 default_hugepagesz=2M hugepagesz=1G hugepages=16 transparent_hugepage=never intel_iommu=on iommu=pt pcie_aspm=force root=ZFS=rpool/ROOT/debian zfs_force=1 boot=zfs "acpi_osi=Windows 2006" systemd.unified_cgroup_hierarchy=1 default_hugepagesz=2M hugepagesz=1G hugepages=16 transparent_hugepage=never intel_iommu=on iommu=pt pcie_aspm=force root=ZFS=rpool/ROOT/debian zfs_force=1 boot=zfs
[ 0.074463] Kernel command line: BOOT_IMAGE=/vmlinuz-6.8.12-6-pve root=ZFS=/ROOT/debian ro "acpi_osi=Windows 2006" systemd.unified_cgroup_hierarchy=1 default_hugepagesz=2M hugepagesz=1G hugepages=16 transparent_hugepage=never intel_iommu=on iommu=pt pcie_aspm=force root=ZFS=rpool/ROOT/debian zfs_force=1 boot=zfs "acpi_osi=Windows 2006" systemd.unified_cgroup_hierarchy=1 default_hugepagesz=2M hugepagesz=1G hugepages=16 transparent_hugepage=never intel_iommu=on iommu=pt pcie_aspm=force root=ZFS=rpool/ROOT/debian zfs_force=1 boot=zfs
[ 0.074662] PCIe ASPM is forcibly enabled
[ 0.074818] PCIe ASPM is forcibly enabled
[ 0.335953] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 22.048698] hailo 0000:01:00.0: Disabling ASPM L0s
[ 22.048756] hailo 0000:01:00.0: Successfully disabled ASPM L0s
[ 22.180487] hailo 0000:02:00.0: Disabling ASPM L0s
[ 22.180559] hailo 0000:02:00.0: Successfully disabled ASPM L0s
[ 22.312762] hailo 0000:08:00.0: Disabling ASPM L0s
[ 22.312827] hailo 0000:08:00.0: Successfully disabled ASPM L0s
And Output of lspci for all 3 different Hailo-8L:
01:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
Subsystem: Hailo Technologies Ltd. Hailo-8 AI Processor
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 42
IOMMU group: 2
Region 0: Memory at f0204000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at f0208000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at f0200000 (64-bit, prefetchable) [size=16K]
Capabilities: [80] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <64ns, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <1us, L1 <2us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L1 Enabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x2 (downgraded)
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt+ EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR+ 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [e0] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee003d8 Data: 0000
Capabilities: [f8] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [100 v1] Vendor Specific Information: ID=1556 Rev=1 Len=008 <?>
Capabilities: [108 v1] Latency Tolerance Reporting
Max snoop latency: 71680ns
Max no snoop latency: 71680ns
Capabilities: [110 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [128 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [200 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 04000001 00000003 01070000 2fef015f
Capabilities: [300 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Kernel driver in use: hailo
Kernel modules: hailo_pci
02:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
Interrupt: pin A routed to IRQ 43
IOMMU group: 2
Region 0: Memory at f0104000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at f0108000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at f0100000 (64-bit, prefetchable) [size=16K]
LnkSta: Speed 8GT/s, Width x1 (downgraded)
Address: 00000000fee003f8 Data: 0000
HeaderLog: 04000001 00000003 02070000 c140b44d
LaneErrStat: 0
08:00.0 Co-processor: Hailo Technologies Ltd. Hailo-8 AI Processor (rev 01)
Interrupt: pin A routed to IRQ 44
IOMMU group: 15
Region 0: Memory at f0004000 (64-bit, prefetchable) [size=16K]
Region 2: Memory at f0008000 (64-bit, prefetchable) [size=4K]
Region 4: Memory at f0000000 (64-bit, prefetchable) [size=16K]
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 25W
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes, Disabled- CommClk+
LnkSta: Speed 5GT/s (downgraded), Width x2 (downgraded)
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Address: 00000000fee00518 Data: 0000
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout+ AdvNonFatalErr-
HeaderLog: 00000000 00000000 00000000 00000000
LaneErrStat: 0
So the relevant Bits are:
And:
And:
So, in Summary:
- According to
dmesg, the hailo_pci Driver explicitely disables ASPM L0s. This can be verified in the hailort-drivers/linux/pcie/src/pcie.c File and the static int hailo_pcie_disable_aspm(struct hailo_pcie_board *board, u16 state, bool locked) Function
- According to
lspci, the Link Supports L0s and L1, but the Device itself supports only L0s with Latency Latency L0s, while L1 is with Latency L1 unlimited, i.e. it will never be able to Resume
What I tried to do (and it appears that this particular Motherboard is COMPLETELY broken with Regards to PCIe ASPM):
- Set Kernel Command Line
pcie_aspm=force
- Set all relevant Options in the BIOS
- Patch the ACPI Tables in InitramFS (fixes
ACPI FADT declares the system doesn't support PCIe ASPM, so disable Error)
- Disassemble BIOS with
UEFITool and ifrextractor, then set some Hidden Options using setup_var.efi Tool from EFI Shell using a .nsh Script
- Edit
hailort-drivers/linux/pcie/src/pcie.c File and set a return 0; at the Beginning of hailo_pcie_disable_aspm(struct hailo_pcie_board *board, u16 state, bool locked) Function to prevent it from executing, so that the Hailo-8L will not force ASPM L0s to be turned off
- Custom Kernel Built to disable Linux Quirk for ASMedia ASM1083/ASM1085 PCIe-to-PCI Devices (which DISABLE ASPM because the PCIe-to-PCI Bridge does NOT Support it)
- Kill/Remove the PCIe Root Port using
echo 1 > /sys/.../remove for the PCIe Root Port associated with the ASMedia ASM1083/ASM1085 Device
- Automatically force ASPM to be enabled L0s + L1 on all Slots using a Script based on GitHub - notthebee/AutoASPM: A script that automatically activates ASPM for all supported devices on Linux
When I applied some Hidden BIOS Settings, the hailo Device in the latest PCIe Address (which was then most likely renamed from 08:00.0 to 05:00.0) started throwing out some DMAR Errors in dmesg and I could also see that its Inference Time in frigate was approx. 5x Times higher than the other Hailo Devices.
And even after all of this, it’s STILL stuck in Package PC2 State
I managed to Undervolt by 90mV the Vcore which according to turbostat seems to have brought down the Package Power Consumption quite a bit (average around 10W).
But the Package C-States will NOT work, no matter what I do unfortunately
