Hailo-8 support on Raspberry Pi 5 with RT-patched Linux?
Does Hailo-8 support running on a Real-Time (RT) patched Linux kernel for the Raspberry Pi 5?
If yes, which Linux distro with RT PATCHED (e.g., Debian, Buildroot, Yocto) ,can we run sucessfully
Thanks!
We don’t currently validate HailoRT on a real-time patched kernel.
That said, both HailoRT and the HailoRT PCIe driver are open source, so you can try running them on the Linux distribution of your choice.
GitHub - HailoRT Hailo-8
GitHub - HailoRT Drivers Hailo-8
We officially validate HailoRT and the PCIe driver on Ubuntu, and we also provide Yocto layers. Debian or Yocto could be good starting points for your setup or experiments.
GitHub - meta-hailo
Hi I wanted to know if power measuremeroot@pi5:/home/pi# hailortcli fw-control identify
Identifying board
Control Protocol Version: 2
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: <N/A>
Part Number: <N/A>
Product Name: <N/A>
above is board details and
and I am gettng error like this
root@pi5:/home/pi# hailortcli measure-power
[HailoRT] [error] Firmware control has failed. Major status: 0x400300b4, Minor status: 0x400300b4
[HailoRT] [error] Firmware major status: CONTROL_PROTOCOL_STATUS_UNSUPPORTED_DEVICE
[HailoRT] [error] Firmware minor status: CONTROL_PROTOCOL_STATUS_UNSUPPORTED_DEVICE
[HailoRT] [error] Opcode HAILO_CONTROL_OPCODE_POWER_MEASUEMENT is not supported on the current board.
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_UNSUPPORTED_OPCODE(48)
[HailoRT CLI] [error] CHECK_SUCCESS failed with status=HAILO_UNSUPPORTED_OPCODE(48)
Failed power measurement, status HAILO_UNSUPPORTED_OPCODE(48)
Failed to execute on device: 0001:01:00.0. status= HAILO_UNSUPPORTED_OPCODE(48)
how to resolve this issue
Power measurement is not supported on the Raspberry Pi AI HAT.
The Hailo-8 M.2 modules have a INA device on board that allows you to measure power. If you want to use a M.2 module on a Raspberry Pi 5, there are multiple options for HATs that you can use. I have tested a few in the past. Have a look at the following post.
Hailo Community - How to connect a Hailo-8 to the Raspberry Pi 5
