Hi Hailo community,
I have official AI Hat for Raspberry Pi with the Hailo-8, and I’ve successfully compiled/converted my model from .onnx to .hef. The model I’m using for testing is version-RFB-640.onnx, which I found in a GitHub repository. This model is intended for face recognition, but just to clarify, I don’t plan to use it in my final app—it’s just for testing purposes. I want to compile it to .hef, run it, and verify the output in Python so that I can train before developing my actual application.
When I ran the hailo parse-hef command, I received the following output:
(hailo) Running command ‘parse-hef’ with ‘hailortcli’
Network group name: version-RFB-640, Single Context
Network name: version-RFB-640/version-RFB-640
VStream infos:
Input version-RFB-640/input_layer1 UINT8, NHWC(480x640x3)
Output version-RFB-640/conv21 UINT8, FCR(60x80x12)
Output version-RFB-640/conv34 UINT8, FCR(8x10x12)
Output version-RFB-640/conv33 UINT8, NHWC(8x10x6)
Output version-RFB-640/conv26 UINT8, NHWC(30x40x8)
Output version-RFB-640/conv30 UINT8, FCR(15x20x4)
Output version-RFB-640/conv20 UINT8, NHWC(60x80x6)
Output version-RFB-640/conv25 UINT8, NHWC(30x40x4)
Output version-RFB-640/conv31 UINT8, FCR(15x20x8)
Now, I want to run this model from Python using GStreamer. I found the apps-infra/gstreamer_helper_pipelines.py file, which helped me create my first pipeline. However, I ran into some issues when trying to execute it. To simplify, I ended up with this pipeline:
pipeline_str = “”"
libcamerasrc ! videoconvert ! videoscale ! video/x-raw,format=RGB,width=640,height=480 !
hailonet hef-path=/version-RFB-640.hef batch-size=20 device-count=1 is_active=true ! appsink name=debug_sink
This works without errors, but it only outputs an image. According to the HailoNet docs, the model output should be in the form of metadata, but I couldn’t find more details or examples on how to extract this metadata. So, I’m unsure whether it’s working as expected.
Initially, I had autovideosink, but I got the following error:
HailoNet Error: gst_pad_push failed with status = -4.
I’ve also seen that hailofilter might help extract metadata from the pipeline, but it requires a so-path argument, and I have no idea what this .so file is or how to create one. I heard you can do this using Cython, but I’m lost when it comes to writing the .so file for my model.
At this point, I’m a bit confused and would really appreciate any help or guidance to move forward. If anyone has worked with similar pipelines or knows how to handle the metadata output, it would be a huge help!
Thanks in advance! ![]()
