Hi everyone,
I have a couple of questions regarding what the Hailo-8 accelerator is optimized for. I asked them on Hailo’s website but I was sent on this forum for answers.
I recently purchased a Raspberry Pi 5 for a personal project involving LLMs. I initially thought about acquiring the AI Hat+ before realizing that it is not optimized for LLMs inference, but rather for computer vision tasks. I got this information from various forums but none explained the technical details as to why.
For another project I have at work currently, I want to run an object detection model on a micro computer, with a video stream coming from a single camera.
I was thus wondering if the Hailo-8 is optimized for any object detection model, even the ones comprising attention-based blocks (DETR for example or latest YOLOs I think).
My questions:
- What makes the Hailo-8 accelerator not suitable for LLMs? I have read that it is due to the number of parameters (several billions) that is too big. Is it only that or the actual nature of the architecture?
- Is the Hailo-8 optimized for all types of object detection models including attention-based ones?
I don’t know the other Hailo products so don’t hesitate to point me to other ones.
Many thanks in advance
Cheers
Antoine
The Hailo Dataflow Compiler can divide networks that do not fit into a single Hailo-8 into multiple contexts. During execution the HailoRT runtime loads these context over PCIe. Some CNNs have a few contexts and provide still good performance. LLM require one hundred or more context which will result in not so good performance while loading the host CPU.
The Hailo-10 has a DDR interface which allows it to run the contexts without the host. There have been some improvements to optimize context switching. Also Hailo-10 can execute two 4-bit operations instead of one 8-bit OP. Because LLM are so large they will use 4-bit layers even more than CNNs to improve efficiency.
Hailo-8 does support transformer based networks. It has a very flexible architecture that allows us to add new layer support via our Hailo Dataflow Compiler. To compare models I recommend you have a look at the Model Explorer in the Developer Zone.
Hailo Model Explorer
Have a look at our Model Zoo and the Explorer. Plenty of models to choose from including the latest YOLOs.
GitHub - Hailo Model Zoo - HAILO8 - Object Detection
Thank you for your response KlausK!
I didn’t get all the technical details. I don’t know what contexts are.
But I understand that the Hailo-10 is dedicated to generative AI.
I’m gonna have a look at the Model Explorer then.
Cheers
Antoine
A context is a part of the model. Context switching is how HailoRT loads and runs these parts sequentially. The terms come from computing, where a context refers to the saved state of a system like CPU registers and memory.
