I’m trying to read the firmware configuration on my Hailo-8 device using hailortcli, but I keep getting an error even though my firmware, library, and driver versions are consistent.
Here’s what I tried:
root@raspberrypi:~# hailortcli fw-control identify
Identifying board
Control Protocol Version: 2
Logger Version: 0
Board Name: Hailo-8
Device Architecture: HAILO8
Serial Number: <N/A>
Part Number: <N/A>
Product Name: <N/A>
Everything looks okay here.
But when I try to read the user config:
root@raspberrypi:~# hailortcli fw-config read
[HailoRT] [warning] Failed to examine user config, as it is not loaded or is not supported by the device.
[HailoRT] [error] Firmware control has failed. Major status: 0x4003003b, Minor status: 0x401a0004
[HailoRT] [error] Firmware major status: CONTROL_PROTOCOL_STATUS_USER_CONFIG_EXAMINE_FAILED
[HailoRT] [error] Firmware minor status: FIRMWARE_CONFIGS_STATUS_USER_CONFIG_NOT_LOADED
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_FW_CONTROL_FAILURE(18)
Environment:
Device: Hailo-8 AI ACC M.2 B+M Key
OS: Raspberry Pi OS
Firmware: 4.20.0
HailoRT library: 4.20.0
Drivers:4.20.0
How to resolve this issue?
