In the hailo8 design guidelines, I found that if the EEPROM is used, it allows for modifications in the board configuration section.
And it said, “if the EEPROM is not detected, the default parameters of the ‘board config’ will be used.”
But i couldn’t find default parameter information in hailo RT or in hailo git.
in hailo git, write board config function looks like write bin file but i can’t find any guide line to make bin for board config.
You would like to know more details about the usage of board configuration and hailo8 default parameter ?
Thanks
