I have install hailort and tappas sucessfully, I want to test how many cameras hailo8l can support so I run this:
https://github.com/hailo-ai/Hailo-Application-Code-Examples/tree/main/runtime/gstreamer/multistream
But I get error like below:
(hailo_env) ain@pi5-hailo:~/tappas/scripts/gstreamer $ ./install_hailo_gstreamer.sh
~/tappas/core/hailo ~/tappas/scripts/gstreamer
Compiling Hailo Gstreamer target all, with 2 cpu cores, build type release --reconfigure
The Meson build system
Version: 0.58.0
Source dir: /home/ain/tappas/core/hailo
Build dir: /home/ain/tappas/core/hailo/build.release
Build type: native build
Project name: gst-hailo-tools
Project version: 3.30.0
C compiler for the host machine: gcc-12 (gcc 12.2.0 "gcc-12 (Debian 12.2.0-14) 12.2.0")
C linker for the host machine: gcc-12 ld.bfd 2.40
C++ compiler for the host machine: g++-12 (gcc 12.2.0 "g++-12 (Debian 12.2.0-14) 12.2.0")
C++ linker for the host machine: g++-12 ld.bfd 2.40
Host machine cpu family: aarch64
Host machine cpu: aarch64
Message: GCC >= 9.0.0 detected, applying extra arguments.
Dependency gstreamer-1.0 found: YES 1.22.0 (cached)
Dependency gstreamer-base-1.0 found: YES 1.22.0 (cached)
Dependency gstreamer-app-1.0 found: YES 1.22.0 (cached)
Dependency gstreamer-video-1.0 found: YES 1.22.0 (cached)
Dependency opencv4 found: YES 4.6.0 (cached)
Dependency glib-2.0 found: YES 2.74.6 (cached)
Dependency gmodule-2.0 found: YES 2.74.6 (cached)
Dependency gobject-2.0 found: YES 2.74.6 (cached)
Dependency pygobject-3.0 found: YES 3.42.2 (cached)
Program python3.11 found: YES (/home/ain/hailo_env/bin/python3.11)
Found pkg-config: /usr/bin/pkg-config (1.8.1)
Dependency python found: YES (pkgconfig)
Configuring config.h using configuration
Library dl found: YES
Dependency libzmq found: YES 4.3.4 (cached)
Dependency threads found: YES unknown (cached)
Library stdc++fs found: YES
Dependency gio-2.0 found: YES 2.74.6 (cached)
Build targets in project: 43
Found ninja-1.10.2.git.kitware.jobserver-1 at /home/ain/hailo_env/bin/ninja
ninja: Entering directory `build.release'
[1/15] Compiling C++ object plugins/hailo.cpython-311-aarch64-linux-gnu.so.p/python_hailo_python_api.cpp.o
FAILED: plugins/hailo.cpython-311-aarch64-linux-gnu.so.p/python_hailo_python_api.cpp.o
g++-12 -Iplugins/hailo.cpython-311-aarch64-linux-gnu.so.p -Iplugins -I../plugins -I../general -I/usr/include/python3.11 -fvisibility=default -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wnon-virtual-dtor -std=c++17 -O3 -Wpessimizing-move -Wredundant-move -fconcepts -fPIC -fsized-deallocation -fvisibility=hidden -isystem../../../open_source/pybind11 -isystem../../open_source/pybind11 -MD -MQ plugins/hailo.cpython-311-aarch64-linux-gnu.so.p/python_hailo_python_api.cpp.o -MF plugins/hailo.cpython-311-aarch64-linux-gnu.so.p/python_hailo_python_api.cpp.o.d -o plugins/hailo.cpython-311-aarch64-linux-gnu.so.p/python_hailo_python_api.cpp.o -c ../plugins/python/hailo_python_api.cpp
../plugins/python/hailo_python_api.cpp:8:10: fatal error: gst_hailo_meta.hpp: No such file or directory
8 | #include "gst_hailo_meta.hpp"
compilation terminated.
[2/15] Linking target plugins/libgsthailotools.so.3.30.0
FAILED: plugins/libgsthailotools.so.3.30.0
g++-12 -o plugins/libgsthailotools.so.3.30.0 plugins/libgsthailotools.so.3.30.0.p/gsthailotools.cpp.o plugins/libgsthailotools.so.3.30.0.p/filter_gsthailofilter.cpp.o plugins/libgsthailotools.so.3.30.0.p/filter_gsthailocounter.cpp.o plugins/libgsthailotools.so.3.30.0.p/muxer_gsthailomuxer.cpp.o plugins/libgsthailotools.so.3.30.0.p/muxer_gsthailoroundrobin.cpp.o plugins/libgsthailotools.so.3.30.0.p/muxer_gsthailostreamrouter.cpp.o plugins/libgsthailotools.so.3.30.0.p/common_image.cpp.o plugins/libgsthailotools.so.3.30.0.p/overlay_overlay.cpp.o plugins/libgsthailotools.so.3.30.0.p/overlay_gsthailooverlay.cpp.o plugins/libgsthailotools.so.3.30.0.p/cropping_gsthailobasecropper.cpp.o plugins/libgsthailotools.so.3.30.0.p/cropping_gsthailocropper.cpp.o plugins/libgsthailotools.so.3.30.0.p/cropping_gsthailoaggregator.cpp.o plugins/libgsthailotools.so.3.30.0.p/tiling_gsthailotilecropper.cpp.o plugins/libgsthailotools.so.3.30.0.p/tiling_gsthailotileaggregator.cpp.o plugins/libgsthailotools.so.3.30.0.p/tracking_gsthailotracker.cpp.o plugins/libgsthailotools.so.3.30.0.p/gallery_gsthailogallery.cpp.o plugins/libgsthailotools.so.3.30.0.p/export_export_file_gsthailoexportfile.cpp.o plugins/libgsthailotools.so.3.30.0.p/export_export_zmq_gsthailoexportzmq.cpp.o plugins/libgsthailotools.so.3.30.0.p/import_import_zmq_gsthailoimportzmq.cpp.o -Wl,--as-needed -Wl,--no-undefined -Wl,-O1 -shared -fPIC -Wl,--start-group -Wl,-soname,libgsthailotools.so.3 '-Wl,-rpath,$ORIGIN/../metadata:$ORIGIN/../tracking' -Wl,-rpath-link,/home/ain/tappas/core/hailo/build.release/metadata -Wl,-rpath-link,/home/ain/tappas/core/hailo/build.release/tracking metadata/libgsthailometa.so.3.30.0 tracking/libhailo_tracker.so.3.30.0 /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so /usr/lib/aarch64-linux-gnu/libgobject-2.0.so /usr/lib/aarch64-linux-gnu/libglib-2.0.so /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so /usr/lib/aarch64-linux-gnu/libgstapp-1.0.so -ldl /usr/lib/aarch64-linux-gnu/libopencv_stitching.so /usr/lib/aarch64-linux-gnu/libopencv_alphamat.so /usr/lib/aarch64-linux-gnu/libopencv_aruco.so /usr/lib/aarch64-linux-gnu/libopencv_barcode.so /usr/lib/aarch64-linux-gnu/libopencv_bgsegm.so /usr/lib/aarch64-linux-gnu/libopencv_bioinspired.so /usr/lib/aarch64-linux-gnu/libopencv_ccalib.so /usr/lib/aarch64-linux-gnu/libopencv_cvv.so /usr/lib/aarch64-linux-gnu/libopencv_dnn_objdetect.so /usr/lib/aarch64-linux-gnu/libopencv_dnn_superres.so /usr/lib/aarch64-linux-gnu/libopencv_dpm.so /usr/lib/aarch64-linux-gnu/libopencv_face.so /usr/lib/aarch64-linux-gnu/libopencv_freetype.so /usr/lib/aarch64-linux-gnu/libopencv_fuzzy.so /usr/lib/aarch64-linux-gnu/libopencv_hdf.so /usr/lib/aarch64-linux-gnu/libopencv_hfs.so /usr/lib/aarch64-linux-gnu/libopencv_img_hash.so /usr/lib/aarch64-linux-gnu/libopencv_intensity_transform.so /usr/lib/aarch64-linux-gnu/libopencv_line_descriptor.so /usr/lib/aarch64-linux-gnu/libopencv_mcc.so /usr/lib/aarch64-linux-gnu/libopencv_quality.so /usr/lib/aarch64-linux-gnu/libopencv_rapid.so /usr/lib/aarch64-linux-gnu/libopencv_reg.so /usr/lib/aarch64-linux-gnu/libopencv_rgbd.so /usr/lib/aarch64-linux-gnu/libopencv_saliency.so /usr/lib/aarch64-linux-gnu/libopencv_shape.so /usr/lib/aarch64-linux-gnu/libopencv_stereo.so /usr/lib/aarch64-linux-gnu/libopencv_structured_light.so /usr/lib/aarch64-linux-gnu/libopencv_phase_unwrapping.so /usr/lib/aarch64-linux-gnu/libopencv_superres.so /usr/lib/aarch64-linux-gnu/libopencv_optflow.so /usr/lib/aarch64-linux-gnu/libopencv_surface_matching.so /usr/lib/aarch64-linux-gnu/libopencv_tracking.so /usr/lib/aarch64-linux-gnu/libopencv_highgui.so /usr/lib/aarch64-linux-gnu/libopencv_datasets.so /usr/lib/aarch64-linux-gnu/libopencv_text.so /usr/lib/aarch64-linux-gnu/libopencv_plot.so /usr/lib/aarch64-linux-gnu/libopencv_ml.so /usr/lib/aarch64-linux-gnu/libopencv_videostab.so /usr/lib/aarch64-linux-gnu/libopencv_videoio.so /usr/lib/aarch64-linux-gnu/libopencv_viz.so /usr/lib/aarch64-linux-gnu/libopencv_wechat_qrcode.so /usr/lib/aarch64-linux-gnu/libopencv_ximgproc.so /usr/lib/aarch64-linux-gnu/libopencv_video.so /usr/lib/aarch64-linux-gnu/libopencv_xobjdetect.so /usr/lib/aarch64-linux-gnu/libopencv_objdetect.so /usr/lib/aarch64-linux-gnu/libopencv_calib3d.so /usr/lib/aarch64-linux-gnu/libopencv_imgcodecs.so /usr/lib/aarch64-linux-gnu/libopencv_features2d.so /usr/lib/aarch64-linux-gnu/libopencv_dnn.so /usr/lib/aarch64-linux-gnu/libopencv_flann.so /usr/lib/aarch64-linux-gnu/libopencv_xphoto.so /usr/lib/aarch64-linux-gnu/libopencv_photo.so /usr/lib/aarch64-linux-gnu/libopencv_imgproc.so /usr/lib/aarch64-linux-gnu/libopencv_core.so /usr/lib/aarch64-linux-gnu/libzmq.so -Wl,--end-group -pthread
/usr/bin/ld: plugins/libgsthailotools.so.3.30.0.p/gsthailotools.cpp.o: in function `plugin_init(_GstPlugin*)':
/home/ain/tappas/core/hailo/build.release/../plugins/gsthailotools.cpp:53: undefined reference to `gst_hailonvalve_get_type'
/usr/bin/ld: /home/ain/tappas/core/hailo/build.release/../plugins/gsthailotools.cpp:55: undefined reference to `gst_hailonv12togray_get_type'
/usr/bin/ld: /home/ain/tappas/core/hailo/build.release/../plugins/gsthailotools.cpp:56: undefined reference to `gst_hailograytonv12_get_type'
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
