I’m new to hailo (but not to ML). I have it on my raspberry pi 5 and trying to figure out how to use it. I’ve downloaded a face detection hef model, and I’m not sure how I can get the (parsed) restuls from it.
I got the retinaface_mobilenet_v1 model from the hailo model zoo Hailo8L (downloaded the hef file)
but the output of the model, is not the same as the one I see in the models’ github page.
In their github page, I can see that in their detect.py file the yodel returns 3 tensors - loc, conf, landms which makes sense. But when I run inference on this model, I see weird output(s). I’m currently running the following code which I took from the HRT_2_Infer_Pipeline_Inference_Tutorial.ipynb from the hailo tutorial. I validated my results with the profile HTML and it looks like it is correct, but I’m not sure how I’m suppose to use it for face detection.
from hailo_platform import (HEF, VDevice, HailoStreamInterface, InferVStreams, ConfigureParams,
InputVStreamParams, OutputVStreamParams, InputVStreams, OutputVStreams, FormatType)
import cv2
# The target can be used as a context manager ("with" statement) to ensure it's released on time.
# Here it's avoided for the sake of simplicity
target = VDevice()
# Loading compiled HEFs to device:
model_name = 'retinaface_mobilenet_v1'
hef_path = '../hefs/{}.hef'.format(model_name)
hef = HEF(hef_path)
# Configure network groups
# Create input and output virtual streams params
input_vstreams_params = InputVStreamParams.make(network_group, format_type=FormatType.FLOAT32)
output_vstreams_params = OutputVStreamParams.make(network_group, format_type=FormatType.UINT8)
# Define dataset params
num_of_images = 10
low, high = 2, 20
def get_imgs_for_model(imgs_dir, target_width, target_height):
imgs_list = glob(f'{imgs_dir}/*.jpg')
imgs = []
target_size = (target_width, target_height)
for img_path in imgs_list:
image = cv2.imread(img_path)
image_rgb = cv2.cvtColor(image, cv2.COLOR_BGR2RGB) # Convert to RGB format if needed
image_resized = cv2.resize(image_rgb, target_size, interpolation=cv2.INTER_AREA)
imgs.append(image_resized[None,...])
return np.concatenate(imgs, axis=0)
imgs = get_imgs_for_model(imgs_dir, image_width, image_height)
# Infer
print('Stream output shape is {}'.format(infer_results[output_vstream_info.name].shape))
The output I’m getting is
```Stream output shape is (5, 92, 160, 8)`
