Face Detection WiderFace Model pipeline_string
Need Help, I tried Hailo RPi5 examples detection.py I wont detect faces
model file : scrfd_10g.hef
I got the model from here Model Zoo by Hailo | AI Model Explorer to Find The Best NN Model
import gi
import os
import argparse
import cv2
import hailo
import setproctitle
from hailo_rpi_common import (
    get_default_parser,
    QUEUE,
    get_caps_from_pad,
    get_numpy_from_buffer,
    GStreamerApp,
    app_callback_class,
# Initialize GStreamer
Gst.init(None)
# User-defined class to be used in the callback function
    def __init__(self):
        super().__init__()
        self.new_variable = 42
    def new_function(self):
        return "The meaning of life is: "
# User-defined callback function
    buffer = info.get_buffer()
    if buffer is None:
        return Gst.PadProbeReturn.OK
    user_data.increment()
    #string_to_print = f"Frame count: {user_data.get_count()}\n"
    string_to_print = ""
    frame = None
    detection_count = 0
    for detection in detections:
        label = detection.get_label()
        bbox = detection.get_bbox()
        if label == "person" and confidence > 0.80:
            string_to_print += f"Detection: {label} {confidence:.2f}\n"
            detection_count += 1
    if user_data.use_frame:
        cv2.putText(frame, f"{user_data.new_function()} {user_data.new_variable}", (10, 60), cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2)
        user_data.set_frame(frame)
    if string_to_print != "":
        print(string_to_print)
# GStreamer Application for Hailo Detection
    def __init__(self, args, user_data):
        super().__init__(args, user_data)
        # Set Hailo parameters
        self.batch_size = 2
        self.network_width = 640
        self.network_height = 640
        self.network_format = "RGB"
        nms_score_threshold = 0.3
        nms_iou_threshold = 0.45
        new_postprocess_path = os.path.join(self.current_path, '../resources/libyolo_hailortpp_post.so')
        if os.path.exists(new_postprocess_path):
            self.default_postprocess_so = new_postprocess_path
        else:
            self.default_postprocess_so = os.path.join(self.postprocess_dir, 'libyolo_hailortpp_post.so')
        if args.hef_path is not None:
            self.hef_path = args.hef_path
        elif args.network == "yolov6n":
            self.hef_path = os.path.join(self.current_path, '../resources/yolov6n.hef')
        elif args.network == "yolov8s":
            self.hef_path = os.path.join(self.current_path, '../resources/yolov8s_h8l.hef')
        elif args.network == "yolox_s_leaky":
            self.hef_path = os.path.join(self.current_path, '../resources/yolox_s_leaky_h8l_mz.hef')
        else:
            assert False, "Invalid network type"
        self.video_source = args.video_source
        if args.labels_json is not None:
            self.labels_config = f' config-path={args.labels_json} '
        else:
            self.labels_config = ''
        self.app_callback = app_callback
        self.thresholds_str = (
            f"output-format-type=HAILO_FORMAT_TYPE_FLOAT32"
        setproctitle.setproctitle("Hailo Detection App")
        self.create_pipeline()
        source_element = (
            f"rtspsrc location={self.video_source} latency=500 ! "
            + QUEUE("queue_dec264")
            + "rtph264depay ! h264parse ! avdec_h264 max-threads=2 ! "
            " video/x-raw, format=I420 ! "
        source_element += QUEUE("queue_scale")
        source_element += "videoscale n-threads=2 ! "
        source_element += QUEUE("queue_src_convert")
        source_element += "videoconvert n-threads=3 name=src_convert qos=false ! "
        source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, pixel-aspect-ratio=1/1 ! "
        pipeline_string = (
            "hailomuxer name=hmux "
            + source_element
            + "tee name=t ! "
            + QUEUE("bypass_queue", max_size_buffers=20)
            + "hmux.sink_0 "
            + "t. ! "
            + QUEUE("queue_hailonet")
            + "videoconvert n-threads=3 ! "
            f"hailonet hef-path={self.hef_path} batch-size={self.batch_size} {self.thresholds_str} force-writable=true ! "
            + QUEUE("queue_hailofilter")
            + f"hailofilter so-path={self.default_postprocess_so} {self.labels_config} qos=false ! "
            + QUEUE("queue_hmuc")
            + "hmux.sink_1 "
            + "hmux. ! "
            + QUEUE("queue_hailo_python")
            + QUEUE("queue_user_callback")
            + "identity name=identity_callback ! "
            + QUEUE("queue_hailooverlay")
            + "hailooverlay ! "
            + QUEUE("queue_videoconvert")
            + "videoconvert n-threads=3 qos=false ! "
            + QUEUE("queue_rtsp")
            + "x264enc tune=zerolatency speed-preset=superfast ! "
            "rtph264pay config-interval=1 pt=96 ! "
            "udpsink host=127.0.0.1 port=8554"
        print(pipeline_string)
        return pipeline_string
if __name__ == "__main__":
    parser = get_default_parser()
    parser.add_argument(
        "--network",
        default="yolov6n",
        choices=['yolov6n', 'yolov8s', 'yolox_s_leaky'],
        help="Which Network to use, default is yolov6n",
        "--hef-path",
        default=None,
        help="Path to HEF file",
        "--labels-json",
        default=None,
        help="Path to costume labels JSON file",
        "--video-source",
        default=None,
        help="Path to video source (default is RTSP)",
    args = parser.parse_args()
    # Start the detection app
    detection_app = GStreamerDetectionApp(args, user_data)
    detection_app.run()
Hi @joms,
That example does not support the scrfd network. As an alternative, you can write an application yourself using as a base the code from our modelzoo:
Hi @joms
If you are interested in getting face detection working on RPi5+Hailo system, we made a simple example: widerface keypoints.
Please see if you find it useful.
Hi @joms
We added postprocessing support for scrfd models. Please see our solution here: SCRFD Model Support in DeGirum PySDK
