I have a model trained on a custom dataset using the Ultralytics YoloV8n-pose network, which has 5 keypoints. I converted the model to ONNX format and compiled it using hailo_sdk_client.
When running inference on an RPi, the following code is used:
import hailo
from hailo_platform import (
HEF,
ConfigureParams,
FormatType,
HailoSchedulingAlgorithm,
HailoStreamInterface,
InferVStreams,
InputVStreamParams,
InputVStreams,
OutputVStreamParams,
OutputVStreams,
VDevice,
params.scheduling_algorithm = HailoSchedulingAlgorithm.NONE
target = VDevice(params=params)
# Loading compiled HEFs to device:
model_name = "aruco"
hef_path = f"{model_name}.hef"
hef = HEF(hef_path)
input_vstreams_params = InputVStreamParams.make(network_group, quantized=False, format_type=FormatType.UINT8)
output_vstreams_params = OutputVStreamParams.make(network_group, quantized=True, format_type=FormatType.UINT8)
# Define dataset params
num_of_images = 7
low, high = 2, 20
dataset = np.load('calibration_data.npy')
# The result output tensor is infer_results[output_vstream_info.name]
print(f"Stream output shape is {infer_results[output_vstream_info.name].shape}")
This program runs successfully, with the infer_results output shape being (7, 1, 8400, 10).
How can I extract the pose keypoints, bounding boxes, and other parameters from the output?
Thank you.
