help me as i am getting this when i tried to install with your PPA. i am not able to run it.
raspberry@raspberry:~/hailo-rpi5-examples$ ./install.sh
📄 Loading configuration from config.yaml
Using config from config.yaml (or defaults):
BASE_URL = http://dev-public.hailo.ai/2025_01
DOWNLOAD_DIR = hailo_temp_resources
HAILORT_VERSION = auto
TAPPAS_CORE_VERSION= auto
VENV_NAME = venv_hailo_rpi_examples
Hailo-Apps-Infra =
@ 25.7.0
TAPPAS_PIP_PKG = auto
TAPPAS_VARIANT = auto
HAILO_INFRA_PATH = auto
CONFIG_FILE = config.yaml
📋 Checking required system packages…
✅ hailort (system) version: 4.22.0-1ubuntu1~marco1
📋 Checking for HailoRT system version
📋 Checking for hailo-tappas vs hailo-tappas-core…
5.0.0-1ubuntu1~marco3
✅ hailo-tappas-core version: 5.0.0-1ubuntu1~marco3
📋 Checking host-Python pip packages…
✅ pip ‘hailort’ version: 4.22.0
⚠️ pip ‘hailo-tappas-core-python-binding’ missing; will install in venv.
📦 Will install missing pip packages in virtualenv.
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
python3-gi is already the newest version (3.48.2-1).
python3-gi-cairo is already the newest version (3.48.2-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
rpi
✅ Virtualenv ‘venv_hailo_rpi_examples’ exists. Activating…
📦 Installing missing pip packages…
📦 Installing ‘hailo-tappas-core-python-binding’ via helper script
→ HAILORT_VERSION = 4.20.0
→ TAPPAS_CORE_VERSION= 3.31.0
→ DOWNLOAD_DIR = hailo_temp_resources
→ install Tapas? = true
→ install HailoRT? = false
→ Downloading Tapas-core wheel…
–2025-11-02 01:21:32-- http://dev-public.hailo.ai/2025_01/tappas_core_python_binding-3.31.0-py3-none-any.whl
Resolving dev-public.hailo.ai (dev-public.hailo.ai)… 2606:4700:10::6814:1714, 2606:4700:10::ac42:af3e, 104.20.23.20, …
Connecting to dev-public.hailo.ai (dev-public.hailo.ai)|2606:4700:10::6814:1714|:80… connected.
HTTP request sent, awaiting response… 301 Moved Permanently
Location: https://dev-public.hailo.ai/2025_01/tappas_core_python_binding-3.31.0-py3-none-any.whl [following]
–2025-11-02 01:21:32-- https://dev-public.hailo.ai/2025_01/tappas_core_python_binding-3.31.0-py3-none-any.whl
Connecting to dev-public.hailo.ai (dev-public.hailo.ai)|2606:4700:10::6814:1714|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 2358233 (2.2M) [application/zip]
Saving to: ‘hailo_temp_resources/tappas_core_python_binding-3.31.0-py3-none-any.whl’
hailo_temp_resources/ 100%[=======================>] 2.25M 4.30MB/s in 0.5s
2025-11-02 01:21:33 (4.30 MB/s) - ‘hailo_temp_resources/tappas_core_python_binding-3.31.0-py3-none-any.whl’ saved [2358233/2358233]
→ Upgrading pip…
Requirement already satisfied: pip in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (25.3)
→ Installing Tapas-core…
Processing ./hailo_temp_resources/tappas_core_python_binding-3.31.0-py3-none-any.whl
tappas-core-python-binding is already installed with the same version as the provided wheel. Use --force-reinstall to force an installation of the wheel.
✅ Installation complete.
/home/raspberry/hailo-rpi5-examples/.env
✅ .env already exists at /home/raspberry/hailo-rpi5-examples/.env
📦 Upgrading pip/setuptools/wheel…
Requirement already satisfied: setuptools in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (80.9.0)
Requirement already satisfied: wheel in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (0.45.1)
Requirement already satisfied: py>=1.8.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (1.11.0)
Requirement already satisfied: numpy<2.0.0 in /usr/lib/python3/dist-packages (from -r requirements.txt (line 1)) (1.26.4)
Requirement already satisfied: setproctitle in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 2)) (1.3.7)
Requirement already satisfied: opencv-python in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 3)) (4.11.0.86)
Requirement already satisfied: pytest in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 4)) (8.4.2)
Requirement already satisfied: pytest-timeout in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 5)) (2.4.0)
Requirement already satisfied: pytest-mock in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 6)) (3.15.1)
Requirement already satisfied: python-dotenv in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from -r requirements.txt (line 7)) (1.2.1)
Requirement already satisfied: iniconfig>=1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from pytest->-r requirements.txt (line 4)) (2.3.0)
Requirement already satisfied: packaging>=20 in /usr/lib/python3/dist-packages (from pytest->-r requirements.txt (line 4)) (24.0)
Requirement already satisfied: pluggy<2,>=1.5 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from pytest->-r requirements.txt (line 4)) (1.6.0)
Requirement already satisfied: pygments>=2.7.2 in /usr/lib/python3/dist-packages (from pytest->-r requirements.txt (line 4)) (2.17.2)
📦 Installing Hailo-Apps-Infra… auto
📦 Installing hailo-apps-infra from Git (25.7.0)…
Collecting hailo-apps
Cloning
(to revision 25.7.0) to /tmp/pip-install-mulabec_/hailo-apps_5392d844339f41ed9377e17a81b0131f
Running command git clone --filter=blob:none --quiet
Running command git checkout -q 2ecfc8662972ad8384546b7dbe79125dfddcb276
Resolved
to commit 2ecfc8662972ad8384546b7dbe79125dfddcb276
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … done
Requirement already satisfied: numpy<2.0.0 in /usr/lib/python3/dist-packages (from hailo-apps) (1.26.4)
Requirement already satisfied: setproctitle in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (1.3.7)
Requirement already satisfied: opencv-python in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (4.11.0.86)
Requirement already satisfied: python-dotenv in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (1.2.1)
Requirement already satisfied: pyyaml in /usr/lib/python3/dist-packages (from hailo-apps) (6.0.1)
Requirement already satisfied: gradio in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (5.49.1)
Requirement already satisfied: fastrtc in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (0.0.33)
Requirement already satisfied: lancedb in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from hailo-apps) (0.25.2)
Requirement already satisfied: matplotlib in /usr/lib/python3/dist-packages (from hailo-apps) (3.6.3)
Requirement already satisfied: Pillow in /usr/lib/python3/dist-packages (from hailo-apps) (10.2.0)
Requirement already satisfied: aioice>=0.10.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from fastrtc->hailo-apps) (0.10.1)
Requirement already satisfied: aiortc in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from fastrtc->hailo-apps) (1.14.0)
Requirement already satisfied: librosa in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from fastrtc->hailo-apps) (0.11.0)
Requirement already satisfied: numba>=0.60.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from fastrtc->hailo-apps) (0.62.1)
Requirement already satisfied: aiofiles<25.0,>=22.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (24.1.0)
Requirement already satisfied: anyio<5.0,>=3.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (4.11.0)
Requirement already satisfied: brotli>=1.1.0 in /usr/lib/python3/dist-packages (from gradio->hailo-apps) (1.1.0)
Requirement already satisfied: fastapi<1.0,>=0.115.2 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.120.4)
Requirement already satisfied: ffmpy in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.6.4)
Requirement already satisfied: gradio-client==1.13.3 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (1.13.3)
Requirement already satisfied: groovy~=0.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.1.2)
Requirement already satisfied: httpx<1.0,>=0.24.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.28.1)
Requirement already satisfied: huggingface-hub<2.0,>=0.33.5 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (1.0.1)
Requirement already satisfied: jinja2<4.0 in /usr/lib/python3/dist-packages (from gradio->hailo-apps) (3.1.2)
Requirement already satisfied: markupsafe<4.0,>=2.0 in /usr/lib/python3/dist-packages (from gradio->hailo-apps) (2.1.5)
Requirement already satisfied: orjson~=3.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (3.11.4)
Requirement already satisfied: packaging in /usr/lib/python3/dist-packages (from gradio->hailo-apps) (24.0)
Requirement already satisfied: pandas<3.0,>=1.0 in /usr/lib/python3/dist-packages (from gradio->hailo-apps) (2.1.4+dfsg)
Requirement already satisfied: pydantic<2.12,>=2.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (2.11.10)
Requirement already satisfied: pydub in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.25.1)
Requirement already satisfied: python-multipart>=0.0.18 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.0.20)
Requirement already satisfied: ruff>=0.9.3 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.14.3)
Requirement already satisfied: safehttpx<0.2.0,>=0.1.6 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.1.7)
Requirement already satisfied: semantic-version~=2.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (2.10.0)
Requirement already satisfied: starlette<1.0,>=0.40.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.49.3)
Requirement already satisfied: tomlkit<0.14.0,>=0.12.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.13.3)
Requirement already satisfied: typer<1.0,>=0.12 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.20.0)
Requirement already satisfied: typing-extensions~=4.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (4.15.0)
Requirement already satisfied: uvicorn>=0.14.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio->hailo-apps) (0.38.0)
Requirement already satisfied: fsspec in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio-client==1.13.3->gradio->hailo-apps) (2025.10.0)
Requirement already satisfied: websockets<16.0,>=13.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from gradio-client==1.13.3->gradio->hailo-apps) (15.0.1)
Requirement already satisfied: idna>=2.8 in /usr/lib/python3/dist-packages (from anyio<5.0,>=3.0->gradio->hailo-apps) (3.6)
Requirement already satisfied: sniffio>=1.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from anyio<5.0,>=3.0->gradio->hailo-apps) (1.3.1)
Requirement already satisfied: annotated-doc>=0.0.2 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from fastapi<1.0,>=0.115.2->gradio->hailo-apps) (0.0.3)
Requirement already satisfied: certifi in /usr/lib/python3/dist-packages (from httpx<1.0,>=0.24.1->gradio->hailo-apps) (2023.11.17)
Requirement already satisfied: httpcore==1.* in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from httpx<1.0,>=0.24.1->gradio->hailo-apps) (1.0.9)
Requirement already satisfied: h11>=0.16 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from httpcore==1.*->httpx<1.0,>=0.24.1->gradio->hailo-apps) (0.16.0)
Requirement already satisfied: filelock in /usr/lib/python3/dist-packages (from huggingface-hub<2.0,>=0.33.5->gradio->hailo-apps) (3.13.1)
Requirement already satisfied: shellingham in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from huggingface-hub<2.0,>=0.33.5->gradio->hailo-apps) (1.5.4)
Requirement already satisfied: tqdm>=4.42.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from huggingface-hub<2.0,>=0.33.5->gradio->hailo-apps) (4.67.1)
Requirement already satisfied: typer-slim in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from huggingface-hub<2.0,>=0.33.5->gradio->hailo-apps) (0.20.0)
Requirement already satisfied: hf-xet<2.0.0,>=1.2.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from huggingface-hub<2.0,>=0.33.5->gradio->hailo-apps) (1.2.0)
Requirement already satisfied: annotated-types>=0.6.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from pydantic<2.12,>=2.0->gradio->hailo-apps) (0.7.0)
Requirement already satisfied: pydantic-core==2.33.2 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from pydantic<2.12,>=2.0->gradio->hailo-apps) (2.33.2)
Requirement already satisfied: typing-inspection>=0.4.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from pydantic<2.12,>=2.0->gradio->hailo-apps) (0.4.2)
Requirement already satisfied: click>=8.0.0 in /usr/lib/python3/dist-packages (from typer<1.0,>=0.12->gradio->hailo-apps) (8.1.6)
Requirement already satisfied: rich>=10.11.0 in /usr/lib/python3/dist-packages (from typer<1.0,>=0.12->gradio->hailo-apps) (13.7.1)
Requirement already satisfied: dnspython>=2.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aioice>=0.10.1->fastrtc->hailo-apps) (2.8.0)
Requirement already satisfied: ifaddr>=0.2.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aioice>=0.10.1->fastrtc->hailo-apps) (0.2.0)
Requirement already satisfied: llvmlite<0.46,>=0.45.0dev0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from numba>=0.60.0->fastrtc->hailo-apps) (0.45.1)
Requirement already satisfied: markdown-it-py>=2.2.0 in /usr/lib/python3/dist-packages (from rich>=10.11.0->typer<1.0,>=0.12->gradio->hailo-apps) (3.0.0)
Requirement already satisfied: pygments<3.0.0,>=2.13.0 in /usr/lib/python3/dist-packages (from rich>=10.11.0->typer<1.0,>=0.12->gradio->hailo-apps) (2.17.2)
Requirement already satisfied: mdurl~=0.1 in /usr/lib/python3/dist-packages (from markdown-it-py>=2.2.0->rich>=10.11.0->typer<1.0,>=0.12->gradio->hailo-apps) (0.1.2)
Requirement already satisfied: av<17.0.0,>=14.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (16.0.1)
Requirement already satisfied: cryptography>=44.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (46.0.3)
Requirement already satisfied: google-crc32c>=1.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (1.7.1)
Requirement already satisfied: pyee>=13.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (13.0.0)
Requirement already satisfied: pylibsrtp>=0.10.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (1.0.0)
Requirement already satisfied: pyopenssl>=25.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from aiortc->fastrtc->hailo-apps) (25.3.0)
Requirement already satisfied: cffi>=2.0.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from cryptography>=44.0.0->aiortc->fastrtc->hailo-apps) (2.0.0)
Requirement already satisfied: pycparser in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from cffi>=2.0.0->cryptography>=44.0.0->aiortc->fastrtc->hailo-apps) (2.23)
Requirement already satisfied: deprecation in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from lancedb->hailo-apps) (2.1.0)
Requirement already satisfied: pyarrow>=16 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from lancedb->hailo-apps) (22.0.0)
Requirement already satisfied: lance-namespace>=0.0.16 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from lancedb->hailo-apps) (0.0.20)
Requirement already satisfied: lance-namespace-urllib3-client in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from lance-namespace>=0.0.16->lancedb->hailo-apps) (0.0.20)
Requirement already satisfied: pylance>=0.18.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from lance-namespace>=0.0.16->lancedb->hailo-apps) (0.38.3)
Requirement already satisfied: python-dateutil>=2.8.2 in /usr/lib/python3/dist-packages (from lance-namespace-urllib3-client->lance-namespace>=0.0.16->lancedb->hailo-apps) (2.8.2)
Requirement already satisfied: urllib3<3.0.0,>=1.25.3 in /usr/lib/python3/dist-packages (from lance-namespace-urllib3-client->lance-namespace>=0.0.16->lancedb->hailo-apps) (2.0.7)
Requirement already satisfied: audioread>=2.1.9 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (3.1.0)
Requirement already satisfied: scipy>=1.6.0 in /usr/lib/python3/dist-packages (from librosa->fastrtc->hailo-apps) (1.11.4)
Requirement already satisfied: scikit-learn>=1.1.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (1.7.2)
Requirement already satisfied: joblib>=1.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (1.5.2)
Requirement already satisfied: decorator>=4.3.0 in /usr/lib/python3/dist-packages (from librosa->fastrtc->hailo-apps) (5.1.1)
Requirement already satisfied: soundfile>=0.12.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (0.13.1)
Requirement already satisfied: pooch>=1.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (1.8.2)
Requirement already satisfied: soxr>=0.3.2 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (1.0.0)
Requirement already satisfied: lazy_loader>=0.1 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (0.4)
Requirement already satisfied: msgpack>=1.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from librosa->fastrtc->hailo-apps) (1.1.2)
Requirement already satisfied: platformdirs>=2.5.0 in /usr/lib/python3/dist-packages (from pooch>=1.1->librosa->fastrtc->hailo-apps) (4.2.0)
Requirement already satisfied: requests>=2.19.0 in /usr/lib/python3/dist-packages (from pooch>=1.1->librosa->fastrtc->hailo-apps) (2.31.0)
Requirement already satisfied: threadpoolctl>=3.1.0 in ./venv_hailo_rpi_examples/lib/python3.12/site-packages (from scikit-learn>=1.1.0->librosa->fastrtc->hailo-apps) (3.6.0)
📦 Installing shared runtime deps…
⚙️ Running post-install…
File “/home/raspberry/hailo-rpi5-examples/venv_hailo_rpi_examples/bin/hailo-post-install”, line 3, in
from hailo_apps.hailo_app_python.core.installation.post_install import main
File “/home/raspberry/hailo-rpi5-examples/venv_hailo_rpi_examples/lib/python3.12/site-packages/hailo_apps/hailo_app_python/core/installation/post_install.py”, line 12, in
from hailo_apps.hailo_app_python.core.common.defines import (
File “/home/raspberry/hailo-rpi5-examples/venv_hailo_rpi_examples/lib/python3.12/site-packages/hailo_apps/hailo_app_python/core/common/defines.py”, line 103, in
TAPPAS_POSTPROC_PATH_DEFAULT = subprocess.check_output(
File “/usr/lib/python3.12/subprocess.py”, line 466, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib/python3.12/subprocess.py”, line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[‘pkg-config’, ‘–variable=tappas_postproc_lib_dir’, ‘hailo-tappas-core’]’ returned non-zero exit status 1.
raspberry@raspberry:~/hailo-rpi5-examples$ dpkg -l | grep -E “hailo|rpicam”
ii hailo-all 4.22.0-1ubuntu1~marco1 all Hailo support (metapackage)
ii hailo-dkms 4.22.0-1ubuntu1~marco1 all Hailo PCIe driver
ii hailo-tappas-core 5.0.0-1ubuntu1~marco3 arm64 This package contains the core components of the Hailo Tappas platform.
ii hailofw 4.22.0-1ubuntu1~marco1 all Hailo firmware
ii hailort 4.22.0-1ubuntu1~marco1 arm64 Hailo RT is a lightweight, production-grade runtime library
ii librpicam-app1:arm64 1.8.1-1ubuntu1~marco1 arm64 Framework for rpicam-apps camera applications
ii python3-hailort 4.22.0-1ubuntu1~marco2 arm64 HailoRT Python API, which wraps the runtime library
ii rpicam-apps 1.8.1-1ubuntu1~marco1 all Camera based applications for Raspberry Pi using the libcamera framework
ii rpicam-apps-core 1.8.1-1ubuntu1~marco1 arm64 Camera based applications for Raspberry Pi using the libcamera framework
ii rpicam-apps-encoder:arm64 1.8.1-1ubuntu1~marco1 arm64 Framework for rpicam-apps camera applications
ii rpicam-apps-hailo-postprocess 1.8.1-1ubuntu1~marco1 arm64 Raspberry Pi AI HAT+ post-processing plugin for rpicam-apps
ii rpicam-apps-opencv-postprocess 1.8.1-1ubuntu1~marco1 arm64 Framework for rpicam-apps camera applications
ii rpicam-apps-preview:arm64 1.8.1-1ubuntu1~marco1 arm64 Framework for rpicam-apps camera applications
