This error pops up when I try to convert my onnx file to hef what should I do?
Is there a way to fix this. I use wsl and python 10 with virtualenv as the documentation suggested i did all the checks and it seems toi be fine where model zoo check example and dfc example worked fine.
make sure you have installed hailort (correct version) .deb and .whl packages.
I had the same problem and solved by downloading these files.
Okay Ill try, Thank you for the advice . Ill try the old version too.
