I tried to ran examples script on rpi5 with hailo ai+ hat . the rpi is installed with ubuntu 24.04
python3 basic_pipelines/detection_simple.py --arch hailo8
Loading environment variables from /home/tiburon/Desktop/sandbox_f/hailo-rpi5-examples/.env...
⚠️ Missing environment variables: %s hailo_arch
Using HEF path: None
Using post-process shared object: None
filesrc location="None" name=source ! queue name=source_queue_decode leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! decodebin name=source_decodebin ! queue name=source_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=source_videoscale n-threads=2 ! queue name=source_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 name=source_convert qos=false ! video/x-raw, pixel-aspect-ratio=1/1, format=RGB, width=640, height=640 ! videorate name=source_videorate ! capsfilter name=source_fps_caps caps="video/x-raw, framerate=30/1" ! queue name=inference_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=inference_videoscale n-threads=2 qos=false ! queue name=inference_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert name=inference_videoconvert n-threads=2 ! queue name=inference_hailonet_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailonet name=inference_hailonet hef-path=None batch-size=2 vdevice-group-id=1 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 force-writable=true ! queue name=inference_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=identity_callback_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=hailo_display_overlay_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay name=hailo_display_overlay ! queue name=hailo_display_videoconvert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert name=hailo_display_videoconvert n-threads=2 qos=false ! queue name=hailo_display_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fpsdisplaysink name=hailo_display video-sink=autovideosink sync=true text-overlay=False signal-fps-measurements=true
[HailoRT] [error] CHECK failed - Failed open /sys/class/hailo_chardev/hailo0/accelerator_type
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_INVALID_RESPONSE(85)
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_DRIVER_INVALID_RESPONSE(85) - Failed parsing device info for hailo0
CHECK_EXPECTED failed with status=85
Error: gst-resource-error-quark: Resource not found. (3), ../plugins/elements/gstfilesrc.c(553): gst_file_src_start (): /GstPipeline:pipeline0/GstFileSrc:source:
No such file "None"
Shutting down... Hit Ctrl-C again to force quit.
uname -r
6.8.0-1040-raspi
what could be the reason?
i followed the tutorial:
hackers-guide-to-the-raspberry-pi-ai-kit-on-ubuntu
