/data/fp/sept-12/hailo-rpi5-examples/basic_pipelines# python detection_simple.py
Loading environment variables from /data/fp/sept-12/hailo-rpi5-examples/.env…
All required environment variables loaded.
Auto-detected Hailo architecture: hailo8l
Using HEF path: /usr/local/hailo/resources/models/hailo8l/yolov6n.hef
Using post-process shared object: /usr/local/hailo/resources/so/libyolo_hailortpp_postprocess.so
filesrc location=“/usr/local/hailo/resources/videos/example_640.mp4” name=source ! queue name=source_queue_decode leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! decodebin name=source_decodebin ! queue name=source_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=source_videoscale n-threads=2 ! queue name=source_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 name=source_convert qos=false ! video/x-raw, pixel-aspect-ratio=1/1, format=RGB, width=640, height=640 ! videorate name=source_videorate ! capsfilter name=source_fps_caps caps=“video/x-raw, framerate=30/1” ! queue name=inference_scale_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale name=inference_videoscale n-threads=2 qos=false ! queue name=inference_convert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! video/x-raw, pixel-aspect-ratio=1/1 ! videoconvert name=inference_videoconvert n-threads=2 ! queue name=inference_hailonet_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailonet name=inference_hailonet hef-path=/usr/local/hailo/resources/models/hailo8l/yolov6n.hef batch-size=2 vdevice-group-id=1 nms-score-threshold=0.3 nms-iou-threshold=0.45 force-writable=true ! queue name=inference_hailofilter_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailofilter name=inference_hailofilter so-path=/usr/local/hailo/resources/so/libyolo_hailortpp_postprocess.so function-name=filter qos=false ! queue name=inference_output_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=identity_callback_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=hailo_display_overlay_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay name=hailo_display_overlay ! queue name=hailo_display_videoconvert_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert name=hailo_display_videoconvert n-threads=2 qos=false ! queue name=hailo_display_q leaky=no max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fpsdisplaysink name=hailo_display video-sink=autovideosink sync=true text-overlay=False signal-fps-measurements=true
terminate called after throwing an instance of ‘std::invalid_argument’
what(): Output tensor yolov6n/yolox_nms_postprocess is not an NMS type
Aborted
