I am using Hailo AI kit with raspberry pi, I am connecting the camera and running the object detection model from hailo-examples, one of my wide angle camera is working fine with the model, but the other cctv camera is not working and giving the below error:
python basic_pipelines/detection.py --input rpi
hailomuxer name=hmux libcamerasrc name=src_0 auto-focus-mode=AfModeManual ! video/x-raw, format=RGB, width=1536, height=864 ! queue name=queue_src_scale max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale ! video/x-raw, format=RGB, width=640, height=640, framerate=30/1 ! queue name=queue_scale max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoscale n-threads=2 ! queue name=queue_src_convert max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 name=src_convert qos=false ! video/x-raw, format=RGB, width=640, height=640, pixel-aspect-ratio=1/1 ! tee name=t ! queue name=bypass_queue max-size-buffers=20 max-size-bytes=0 max-size-time=0 ! hmux.sink_0 t. ! queue name=queue_hailonet max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 ! hailonet hef-path=/home/maheedhar/hailo-rpi5-examples/basic_pipelines/../resources/yolov6n.hef batch-size=2 nms-score-threshold=0.3 nms-iou-threshold=0.45 output-format-type=HAILO_FORMAT_TYPE_FLOAT32 force-writable=true ! queue name=queue_hailofilter max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailofilter so-path=/usr/lib/aarch64-linux-gnu/hailo/tappas//post-process/libyolo_hailortpp_post.so qos=false ! queue name=queue_hmuc max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hmux.sink_1 hmux. ! queue name=queue_hailo_python max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! queue name=queue_user_callback max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! identity name=identity_callback ! queue name=queue_hailooverlay max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! hailooverlay ! queue name=queue_videoconvert max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! videoconvert n-threads=3 qos=false ! queue name=queue_hailo_display max-size-buffers=3 max-size-bytes=0 max-size-time=0 ! fpsdisplaysink video-sink=xvimagesink name=hailo_display sync=false text-overlay=False signal-fps-measurements=true
[0:00:33.128773609] [2074] INFO Camera camera_manager.cpp:313 libcamera v0.3.0+65-6ddd79b5
[0:00:33.135920979] [2091] INFO RPI pisp.cpp:695 libpisp version v1.0.6 b567f0455680 13-08-2024 (13:30:39)
[0:00:33.145148590] [2091] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@88000/imx296@1a to CFE device /dev/media0 and ISP device /dev/media1 using PiSP variant BCM2712_C0
Error: gst-stream-error-quark: Internal data stream error. (1), ../src/gstreamer/gstlibcamerasrc.cpp(646): gst_libcamera_src_task_enter (): /GstPipeline:pipeline0/GstLibcameraSrc:src_0:
streaming stopped, reason not-negotiated (-4)
