Error during editing main window : Failed to map buffer for writing
def process_frame_callback(pad, info, user_data):
buffer = info.get_buffer()
if buffer is None:
return Gst.PadProbeReturn.OK
# Parse the detections and draw them
detection_count = 0
for detection in detections:
    label = detection.get_label()
    bbox = detection.get_bbox()
    if label == "person":  # or whatever classes you're detecting
        # Draw your custom overlays here
        x1, y1, x2, y2 = int(bbox.xmin), int(bbox.ymin), int(bbox.xmax), int(bbox.ymax)
        cv2.rectangle(frame, (x1, y1), (x2, y2), (0, 255, 0), 2)
        cv2.putText(frame, f"{label}: {confidence:.2f}", (x1, y1-10),
                   cv2.FONT_HERSHEY_SIMPLEX, 0.5, (0, 255, 0), 2)
        detection_count += 1
# Add your custom overlays to the main frame
cv2.putText(frame, "Custom Text", (50, 50), cv2.FONT_HERSHEY_SIMPLEX, 1, (255, 0, 0), 2)
cv2.circle(frame, (width // 2, height // 2), 30, (0, 255, 255), 3)
cv2.putText(frame, f"Detections: {detection_count}", (10, 30),
            cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2)
# Write the modified frame back into the GStreamer buffer
success, map_info = buffer.map(Gst.MapFlags.WRITE)
if not success:
    print("Failed to map buffer for writing")
try:
    # Convert the frame to RGB (GStreamer format) and copy it back to the buffer
    modified_frame = cv2.cvtColor(frame, cv2.COLOR_BGR2RGB)
    # Copy the modified frame back to the buffer
    np.copyto(np.ndarray(shape=(height, width, 3), dtype=np.uint8, buffer=map_info.data), modified_frame)
    # np.copyto(np.ndarray(shape=(height, width, 3), dtype=np.uint8, buffer=map_info.data), frame)
except Exception as e:
    print(f"Error writing to buffer: {e}")
finally:
    buffer.unmap(map_info)
Hi @ssms1225,
It seems like the error message “Failed to map buffer for writing” is usually related to either permission issues or the buffer’s state when trying to write data to it. Here are a couple of things you can try to resolve this:
  1. Permissions: Double-check that all the files and folders your script is using have the necessary write permissions. Make sure your script has the appropriate access rights to modify these files.
  2. Buffer Status: Before trying to map the buffer, it’s a good idea to verify that the buffer is not None and is actually valid. You can add a simple check like this:
if not buffer:
    print("Buffer is None or invalid")
This will print a message if the buffer is None or invalid, and then return Gst.PadProbeReturn.OK to continue the pipeline’s normal operation.
Let me know if these suggestions help or if you need any further assistance!
Hi, omria
I already did that but the result is the same. Below is a combined code for hailo_common_funcs.py, hailo_rpi_common.py and object_detection_hailo.py. Currently, I can see only for my customized inference. I really want to edit main window. It’s not easy for me to do that. These are some prints of my customized lss_callback function:
lss_data id: 140731942412560
lss_data.use_frame: False
Frame not retrieved due to missing format or dimensions.
label: JJH, bbox: <hailo.HailoBBox(140731448667904)>, confidence: 0.15631043910980225
Frame count: 0
import gi
from gi.repository import Gst, GObject, GLib
import os
import argparse
import multiprocessing
import setproctitle
import cv2
import time
import json
import hailo
import supervision as sv
# Try to import hailo python module
try:
    import hailo
except ImportError:
    exit("Failed to import hailo python module. Make sure you are in hailo virtual environment.")
# Functions used to get numpy arrays from GStreamer buffers
def handle_rgb(map_info, width, height):
    return np.ndarray(shape=(height, width, 3), dtype=np.uint8, buffer=map_info.data).copy()
def handle_nv12(map_info, width, height):
    y_plane_size = width * height
    uv_plane_size = width * height // 2
    y_plane = np.ndarray(shape=(height, width), dtype=np.uint8, buffer=map_info.data[:y_plane_size]).copy()
    uv_plane = np.ndarray(shape=(height // 2, width // 2, 2), dtype=np.uint8,
                          buffer=map_info.data[y_plane_size:]).copy()
    return y_plane, uv_plane
def handle_yuyv(map_info, width, height):
    return np.ndarray(shape=(height, width, 2), dtype=np.uint8, buffer=map_info.data).copy()
FORMAT_HANDLERS = {
    'RGB': handle_rgb,
    'NV12': handle_nv12,
    'YUYV': handle_yuyv,
def get_numpy_from_buffer(buffer, format, width, height):
    success, map_info = buffer.map(Gst.MapFlags.READ)
    if not success:
        raise ValueError("Buffer mapping failed")
    try:
        handler = FORMAT_HANDLERS.get(format)
        if handler is None:
            raise ValueError(f"Unsupported format: {format}")
        return handler(map_info, width, height)
    finally:
# Useful functions for working with GStreamer
def disable_qos(pipeline):
    if not isinstance(pipeline, Gst.Pipeline):
        print("The provided object is not a GStreamer Pipeline")
        return
    it = pipeline.iterate_elements()
    while True:
        result, element = it.next()
        if result != Gst.IteratorResult.OK:
            break
        if 'qos' in GObject.list_properties(element):
            element.set_property('qos', False)
            print(f"Set qos to False for {element.get_name()}")
# User defined class to be used in the callback function
class lss_callback_class:
    def __init__(self):
        self.frame_count = 0
        self.use_frame = False
        self.frame_queue = multiprocessing.Queue(maxsize=3)
        self.running = True
    def increment(self):
        self.frame_count += 1
    def get_count(self):
        return self.frame_count
    def set_frame(self, frame):
        if not self.frame_queue.full():
            self.frame_queue.put(frame)
    def get_frame(self):
        if not self.frame_queue.empty():
            return self.frame_queue.get()
        else:
            return None
# Common functions
def get_caps_from_pad(pad: Gst.Pad):
    caps = pad.get_current_caps()
    if caps:
        structure = caps.get_structure(0)
        if structure:
            format = structure.get_value('format')
            width = structure.get_value('width')
            height = structure.get_value('height')
            return format, width, height
    return None, None, None
def display_user_data_frame(lss_data: lss_callback_class):
    while lss_data.running:
        frame = lss_data.get_frame()
        if frame is not None:
            cv2.imshow("User Frame", frame)
        cv2.waitKey(1)
    cv2.destroyAllWindows()
def display_lss_data_frame(lss_data: lss_callback_class):
        cv2.waitKey(1)
def get_default_parser():
    parser = argparse.ArgumentParser(description="Hailo App Help")
    parser.add_argument("--input", "-i", type=str, default="/dev/video0", help="Input source. Can be a file, USB or RPi camera (CSI camera module). \
                        For RPi camera use '-i rpi' (Still in Beta). \
                        Defaults to /dev/video0")
    parser.add_argument("--use-frame", "-u", action="store_true", help="Use frame from the callback function")
    parser.add_argument("--show-fps", "-f", action="store_true", help="Print FPS on sink")
    parser.add_argument("--disable-sync", action="store_true", help="Disables display sink sync, will run as fast possible. Relevant when using file source.")
    parser.add_argument("--dump-dot", action="store_true", help="Dump the pipeline graph to a dot file pipeline.dot")
    return parser
def QUEUE(name, max_size_buffers=3, max_size_bytes=0, max_size_time=0):
    return f"queue name={name} max-size-buffers={max_size_buffers} max-size-bytes={max_size_bytes} max-size-time={max_size_time} ! "
def get_source_type(input_source):
    if input_source.startswith("/dev/video"):
        return 'usb'
    else:
        if input_source.startswith("rpi"):
            return 'rpi'
        else:
            return 'file'
def USER_CALLBACK_PIPELINE(name='identity_callback'):
    return f'{QUEUE(name=f"{name}_q")} ! identity name={name}'
# GStreamerApp class
class GStreamerApp:
    def __init__(self, args, lss_data: lss_callback_class):
        # def __init__(self, args, process_frame_callback: lss_callback_class):
        # Set the process title
        setproctitle.setproctitle("Hailo Python App")
        # Create an empty options menu
        self.options_menu = args
        # Initialize variables
        tappas_postprocess_dir = os.environ.get('TAPPAS_POST_PROC_DIR', '')
        if tappas_postprocess_dir == '':
            print("TAPPAS_POST_PROC_DIR environment variable is not set. Please set it to by sourcing setup_env.sh")
            exit(1)
        self.current_path = os.path.dirname(os.path.abspath(__file__))
        self.postprocess_dir = tappas_postprocess_dir
        self.video_source = self.options_menu.input
        self.source_type = get_source_type(self.video_source)
        # self.user_data = user_data
        self.lss_data = lss_data
        # self.video_sink = "xvimagesink"
        self.video_sink = "autovideosink"
        # self.video_sink = "fakesink"
        # Set Hailo parameters these parameters shuold be set based on the model used
        self.batch_size = 1
        self.network_width = 640
        self.network_height = 640
        self.network_format = "RGB"
        self.default_postprocess_so = None
        self.hef_path = None
        self.app_callback = None
        self.lss_callback = lss_callback_class
        # Set user data parameters
        lss_data.use_frame = self.options_menu.use_frame
        if (self.options_menu.disable_sync or self.source_type != "file"):
            self.sync = "false"
        else:
            self.sync = "true"
        if (self.options_menu.dump_dot):
            os.environ["GST_DEBUG_DUMP_DOT_DIR"] = self.current_path
    def on_fps_measurement(self, sink, fps, droprate, avgfps):
        print(f"FPS: {fps:.2f}, Droprate: {droprate:.2f}, Avg FPS: {avgfps:.2f}")
        return True
    def create_pipeline(self):
        # Initialize GStreamer
        Gst.init(None)
        pipeline_string = self.get_pipeline_string()
        try:
            self.pipeline = Gst.parse_launch(pipeline_string)
            identity = self.pipeline.get_by_name("identity_callback")
            if identity:
                identity_pad = identity.get_static_pad("src")
                identity_pad.add_probe(Gst.PadProbeType.BUFFER, self.lss_callback, self.lss_data)
            print(e)
            print(pipeline_string)
            exit(1)
        # connect to hailo_display fps-measurements
        if (self.options_menu.show_fps):
            print("Showing FPS")
            self.pipeline.get_by_name("hailo_display").connect("fps-measurements", self.on_fps_measurement)
        # Create a GLib Main Loop
        self.loop = GLib.MainLoop()
    def bus_call(self, bus, message, loop):
        t = message.type
        if t == Gst.MessageType.EOS:
            print("End-of-stream")
            loop.quit()
        elif t == Gst.MessageType.ERROR:
            err, debug = message.parse_error()
            print(f"Error: {err}, {debug}")
            loop.quit()
        # QOS
        elif t == Gst.MessageType.QOS:
            # Handle QoS message here
            qos_element = message.src.get_name()
            print(f"QoS message received from {qos_element}")
        return True
        return ""
    def dump_dot_file(self):
        print("Dumping dot file...")
        Gst.debug_bin_to_dot_file(self.pipeline, Gst.DebugGraphDetails.ALL, "pipeline")
        return False
    def run(self):
        # Add a watch for messages on the pipeline's bus
        bus = self.pipeline.get_bus()
        bus.add_signal_watch()
        bus.connect("message", self.bus_call, self.loop)
        # get xvimagesink element and disable qos
        # xvimagesink is instantiated by fpsdisplaysink
        hailo_display = self.pipeline.get_by_name("hailo_display")
        if hailo_display is None:
            print(
                "Warning: hailo_display element not found, add <fpsdisplaysink name=hailo_display> to your pipeline to support fps display.")
        else:
            xvimagesink = hailo_display.get_by_name("xvimagesink0")
            if xvimagesink is not None:
                xvimagesink.set_property("qos", False)
        # Disable QoS to prevent frame drops
        disable_qos(self.pipeline)
        # start a sub process to run the display_user_data_frame function
        if (self.options_menu.use_frame):
            # display_process = multiprocessing.Process(target=display_user_data_frame, args=(self.user_data,))
            display_process = multiprocessing.Process(target=display_user_data_frame, args=(self.lss_data,))
            display_process.start()
        # Set pipeline to PLAYING state
        self.pipeline.set_state(Gst.State.PLAYING)
        # dump dot file
            GLib.timeout_add_seconds(3, self.dump_dot_file)
        # Run the GLib event loop
        try:
            self.loop.run()
        except:
            pass
        # Clean up
        self.lss_data.running = False
        self.pipeline.set_state(Gst.State.NULL)
            display_process.terminate()
            display_process.join()
# User defined callback function
def lss_callback(pad, info, lss_data):
    print(f"lss_data id: {id(lss_data)}")
    print(f"lss_data.use_frame: {lss_data.use_frame}")
    if buffer is None:
    string_to_print = f"Frame count: {lss_data.get_count()}\n"
    frame = None  # Initialize frame to None
    if lss_data.use_frame and format and width and height:
        if frame is None:
            print("Failed to get frame from buffer.")
        else:
            print(f"Frame shape: {frame.shape}")
    else:
        print("Frame not retrieved due to missing format or dimensions.")
    detection_count = 0
        print(f"label: {label}, bbox: {bbox}, confidence: {confidence}")
        if label != "JJH" and lss_data.use_frame:
                cv2.rectangle(frame, (int(bbox.xmin()), int(bbox.ymin())), (int(bbox.xmax()), int(bbox.ymax())), (0, 255, 0), 2)
                x1_norm = bbox.xmin()
                y1_norm = bbox.ymin()
                x2_norm = bbox.xmax()
                y2_norm = bbox.ymax()
                x1 = int(x1_norm * width)
                y1 = int(y1_norm * height)
                x2 = int(x2_norm * width)
                y2 = int(y2_norm * height)
                okay_bbox = (x1, y1, x2 - x1, y2 - y1)
                string_to_print += f"Detection {detection_count}: Label = {label}, BBox = {okay_bbox}, Confidence = {confidence:.2f}\n"
                output_dir = '/opt/iot/results'
                output_path = os.path.join(output_dir, f"frame_{lss_data.get_count()}.jpg")
                cv2.imwrite(output_path, cv2.cvtColor(frame, cv2.COLOR_RGB2BGR))
                print(f"Saved frame to {output_path}")
    if detection_count > 0:
        string_to_print += f"Total detections: {detection_count}\n"
    if lss_data.use_frame and frame is not None:
        lss_data.set_frame(frame)
    print(string_to_print)
# User Gstreamer Application
    def __init__(self, args, lss_data):
        super().__init__(args, lss_data)
        self.batch_size = 2
        self.default_postprocess_so = os.path.join(self.postprocess_dir, 'libyolo_hailortpp_post.so')
        # self.thresholds_str = ""  # Initialize thresholds_str as empty string
        if args.network == "yolov6n":
            self.hef_path = os.path.join(self.current_path, './hailomodel/yolov6n.hef')
        elif args.network == "yolov8s":
            self.hef_path = os.path.join(self.current_path, './hailomodel/yolov8s_h8l.hef')
        elif args.network == "yolov8n":
            nms_score_threshold = 0.1
            nms_iou_threshold = 0.1
            self.thresholds_str = f"nms-score-threshold={nms_score_threshold} nms-iou-threshold={nms_iou_threshold} output-format-type=HAILO_FORMAT_TYPE_FLOAT32"
            self.hef_path = os.path.join(self.current_path, './hailomodel/eeg_employee_2.hef')
        elif args.network == "yolox_s_leaky":
            self.hef_path = os.path.join(self.current_path, './hailomodel/yolox_s_leaky_h8l_mz.hef')
        else:
            assert False, "Invalid network type"
        setproctitle.setproctitle("Hailo Detection App")
        self.create_pipeline()
        if (self.source_type == "rpi"):
            source_element = f"libcamerasrc name=src_0 auto-focus-mode=2 ! "
            source_element += f"video/x-raw, format={self.network_format}, width=1536, height=864 ! "
            source_element += QUEUE("queue_src_scale")
            source_element += f"videoscale ! "
            source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
        elif (self.source_type == "usb"):
            source_element = f"v4l2src device={self.video_source} name=src_0 ! "
            source_element += f"video/x-raw, width=640, height=480, framerate=30/1 ! "
        else:
            source_element = f"filesrc location={self.video_source} name=src_0 ! "
            source_element += QUEUE("queue_dec264")
            source_element += f" qtdemux ! h264parse ! avdec_h264 max-threads=2 ! "
            source_element += f" video/x-raw,format=I420 ! "
        source_element += QUEUE("queue_scale")
        source_element += f" videoscale n-threads=2 ! "
        source_element += QUEUE("queue_src_convert")
        source_element += f" videoconvert n-threads=3 name=src_convert qos=false ! "
        source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, pixel-aspect-ratio=1/1 ! "
        pipeline_string = "hailomuxer name=hmux "
        pipeline_string += source_element
        pipeline_string += "tee name=t ! "
        pipeline_string += QUEUE("bypass_queue", max_size_buffers=20) + "hmux.sink_0 "
        pipeline_string += "t. ! " + QUEUE("queue_hailonet")
        pipeline_string += "videoconvert n-threads=3 ! "
        pipeline_string += f"hailonet hef-path={self.hef_path} batch-size={self.batch_size} {self.thresholds_str} force-writable=true ! "
        pipeline_string += QUEUE("queue_hailofilter")
        self.json_config_path = "./resource/eeg_employee_2.json"
        pipeline_string += f"hailofilter function-name=\"filter\" so-path={self.default_postprocess_so} config-path={self.json_config_path} qos=false ! "
        pipeline_string += QUEUE("queue_hmuc") + " hmux.sink_1 "
        pipeline_string += "hmux. ! " + QUEUE("queue_hailo_python")
        pipeline_string += QUEUE("queue_user_callback")
        pipeline_string += f"identity name=identity_callback ! "
        pipeline_string += QUEUE("queue_hailooverlay")
        pipeline_string += f"hailooverlay ! "
        pipeline_string += QUEUE("queue_videoconvert")
        pipeline_string += f"videoconvert n-threads=3 qos=false ! "
        pipeline_string += QUEUE("queue_hailo_display")
        pipeline_string += f"fpsdisplaysink video-sink={self.video_sink} name=hailo_display sync={self.sync} text-overlay={self.options_menu.show_fps} signal-fps-measurements=true "
        return pipeline_string
if __name__ == "__main__":
    parser = get_default_parser()
    # Add additional arguments here
    parser.add_argument("--network", default="yolov8n", choices=['yolov6n', 'yolov8s', 'yolox_s_leaky'],
                        help="Which Network to use, defult is yolov6n")
    args = parser.parse_args()
    lss_data = lss_callback_class()
    # app = GStreamerDetectionApp(args, user_data)
    app = GStreamerDetectionApp(args, lss_data)
    print("Starting GStreamerDetectionApp")
    begin = time.time()
    app.run()
    print("Application run completed")
    end = time.time()
    print("Total time: ", 733 / (end - begin))
