Hi, Omria
Recently, I came to know that this command is working and I can see live streaming from it.
gst-launch-1.0 v4l2src device=/dev/video0 ! image/jpeg,width=320,height=240,framerate=15/1 ! jpegdec ! autovideosink
Could you help me modify my combined script to edit the main window?
import gi
from gi.repository import Gst, GObject, GLib
import os
import argparse
import multiprocessing
import setproctitle
import cv2
import time
import json
import hailo
import supervision as sv
# Try to import hailo python module
try:
import hailo
except ImportError:
exit("Failed to import hailo python module. Make sure you are in hailo virtual environment.")
# Functions used to get numpy arrays from GStreamer buffers
def handle_rgb(map_info, width, height):
return np.ndarray(shape=(height, width, 3), dtype=np.uint8, buffer=map_info.data).copy()
def handle_nv12(map_info, width, height):
y_plane_size = width * height
uv_plane_size = width * height // 2
y_plane = np.ndarray(shape=(height, width), dtype=np.uint8, buffer=map_info.data[:y_plane_size]).copy()
uv_plane = np.ndarray(shape=(height // 2, width // 2, 2), dtype=np.uint8,
buffer=map_info.data[y_plane_size:]).copy()
return y_plane, uv_plane
def handle_yuyv(map_info, width, height):
return np.ndarray(shape=(height, width, 2), dtype=np.uint8, buffer=map_info.data).copy()
FORMAT_HANDLERS = {
'RGB': handle_rgb,
'NV12': handle_nv12,
'YUYV': handle_yuyv,
def get_numpy_from_buffer(buffer, format, width, height):
success, map_info = buffer.map(Gst.MapFlags.READ)
if not success:
raise ValueError("Buffer mapping failed")
try:
# format='YUYV'
handler = FORMAT_HANDLERS.get(format)
if handler is None:
raise ValueError(f"Unsupported format: {format}")
return handler(map_info, width, height)
finally:
buffer.unmap(map_info)
# Useful functions for working with GStreamer
def disable_qos(pipeline):
if not isinstance(pipeline, Gst.Pipeline):
print("The provided object is not a GStreamer Pipeline")
return
it = pipeline.iterate_elements()
while True:
result, element = it.next()
if result != Gst.IteratorResult.OK:
break
if 'qos' in GObject.list_properties(element):
element.set_property('qos', False)
print(f"Set qos to False for {element.get_name()}")
# User defined class to be used in the callback function
class lss_callback_class:
def __init__(self):
self.frame_count = 0
self.use_frame = False
self.frame_queue = multiprocessing.Queue(maxsize=3)
self.running = True
def increment(self):
self.frame_count += 1
def get_count(self):
return self.frame_count
def set_frame(self, frame):
if not self.frame_queue.full():
self.frame_queue.put(frame)
def get_frame(self):
if not self.frame_queue.empty():
return self.frame_queue.get()
else:
return None
# Common functions
def get_caps_from_pad(pad: Gst.Pad):
caps = pad.get_current_caps()
if caps:
structure = caps.get_structure(0)
if structure:
format = structure.get_value('format')
width = structure.get_value('width')
height = structure.get_value('height')
return format, width, height
return None, None, None
def display_user_data_frame(lss_data: lss_callback_class):
while lss_data.running:
frame = lss_data.get_frame()
if frame is not None:
cv2.imshow("User Frame", frame)
cv2.waitKey(1)
cv2.destroyAllWindows()
def display_lss_data_frame(lss_data: lss_callback_class):
# Add custom overlays
cv2.putText(frame, "Custom Overlay Text", (10, 50), cv2.FONT_HERSHEY_SIMPLEX, 1, (255, 0, 0), 2)
cv2.circle(frame, (frame.shape[1] // 2, frame.shape[0] // 2), 50, (0, 255, 0), 3)
cv2.waitKey(1)
def get_default_parser():
parser = argparse.ArgumentParser(description="Hailo App Help")
parser.add_argument("--input", "-i", type=str, default="/dev/video0", help="Input source. Can be a file, USB or RPi camera (CSI camera module). \
For RPi camera use '-i rpi' (Still in Beta). \
Defaults to /dev/video0")
parser.add_argument("--use-frame", "-u", action="store_true", help="Use frame from the callback function")
parser.add_argument("--show-fps", "-f", action="store_true", help="Print FPS on sink")
parser.add_argument("--disable-sync", action="store_true", help="Disables display sink sync, will run as fast possible. Relevant when using file source.")
parser.add_argument("--dump-dot", action="store_true", help="Dump the pipeline graph to a dot file pipeline.dot")
return parser
def QUEUE(name, max_size_buffers=3, max_size_bytes=0, max_size_time=0):
return f"queue name={name} max-size-buffers={max_size_buffers} max-size-bytes={max_size_bytes} max-size-time={max_size_time} ! "
def get_source_type(input_source):
if input_source.startswith("/dev/video"):
return 'usb'
else:
if input_source.startswith("rpi"):
return 'rpi'
else:
return 'file'
def USER_CALLBACK_PIPELINE(name='identity_callback'):
return f'{QUEUE(name=f"{name}_q")} ! identity name={name}'
# GStreamerApp class
class GStreamerApp:
def __init__(self, args, lss_data: lss_callback_class):
# def __init__(self, args, process_frame_callback: lss_callback_class):
# Set the process title
setproctitle.setproctitle("Hailo Python App")
# Create an empty options menu
self.options_menu = args
# Initialize variables
tappas_postprocess_dir = os.environ.get('TAPPAS_POST_PROC_DIR', '')
if tappas_postprocess_dir == '':
print("TAPPAS_POST_PROC_DIR environment variable is not set. Please set it to by sourcing setup_env.sh")
exit(1)
self.current_path = os.path.dirname(os.path.abspath(__file__))
self.postprocess_dir = tappas_postprocess_dir
self.video_source = self.options_menu.input
self.source_type = get_source_type(self.video_source)
# self.user_data = user_data
self.lss_data = lss_data
# self.video_sink = "xvimagesink"
self.video_sink = "autovideosink"
# self.video_sink = "fakesink"
# Set Hailo parameters these parameters shuold be set based on the model used
self.batch_size = 1
# self.network_width = 640
# self.network_height = 640
# self.network_width = 1080
# self.network_height = 720
# self.network_height = 480
self.network_width = 320
self.network_height = 240
self.network_format = "RGB"
# self.network_format = "YUYV"
self.default_postprocess_so = None
self.hef_path = None
self.app_callback = None
self.lss_callback = lss_callback_class
# Set user data parameters
lss_data.use_frame = self.options_menu.use_frame
if (self.options_menu.disable_sync or self.source_type != "file"):
self.sync = "false"
else:
self.sync = "true"
if (self.options_menu.dump_dot):
os.environ["GST_DEBUG_DUMP_DOT_DIR"] = self.current_path
def on_fps_measurement(self, sink, fps, droprate, avgfps):
print(f"FPS: {fps:.2f}, Droprate: {droprate:.2f}, Avg FPS: {avgfps:.2f}")
return True
def create_pipeline(self):
# Initialize GStreamer
Gst.init(None)
pipeline_string = self.get_pipeline_string()
try:
self.pipeline = Gst.parse_launch(pipeline_string)
identity = self.pipeline.get_by_name("identity_callback")
if identity:
identity_pad = identity.get_static_pad("src")
identity_pad.add_probe(Gst.PadProbeType.BUFFER, self.lss_callback, self.lss_data)
except Exception as e:
print(e)
print(pipeline_string)
exit(1)
# connect to hailo_display fps-measurements
if (self.options_menu.show_fps):
print("Showing FPS")
self.pipeline.get_by_name("hailo_display").connect("fps-measurements", self.on_fps_measurement)
# Create a GLib Main Loop
self.loop = GLib.MainLoop()
def bus_call(self, bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
print("End-of-stream")
loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
print(f"Error: {err}, {debug}")
loop.quit()
# QOS
elif t == Gst.MessageType.QOS:
# Handle QoS message here
qos_element = message.src.get_name()
print(f"QoS message received from {qos_element}")
return True
return ""
def dump_dot_file(self):
print("Dumping dot file...")
Gst.debug_bin_to_dot_file(self.pipeline, Gst.DebugGraphDetails.ALL, "pipeline")
return False
def run(self):
# Add a watch for messages on the pipeline's bus
bus = self.pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", self.bus_call, self.loop)
# get xvimagesink element and disable qos
# xvimagesink is instantiated by fpsdisplaysink
hailo_display = self.pipeline.get_by_name("hailo_display")
if hailo_display is None:
print(
"Warning: hailo_display element not found, add <fpsdisplaysink name=hailo_display> to your pipeline to support fps display.")
else:
xvimagesink = hailo_display.get_by_name("xvimagesink0")
if xvimagesink is not None:
xvimagesink.set_property("qos", False)
# Disable QoS to prevent frame drops
disable_qos(self.pipeline)
# start a sub process to run the display_user_data_frame function
if (self.options_menu.use_frame):
# display_process = multiprocessing.Process(target=display_user_data_frame, args=(self.user_data,))
# display_process = multiprocessing.Process(target=display_user_data_frame, args=(self.lss_data,))
display_process = multiprocessing.Process(target=display_lss_data_frame, args=(self.lss_data,))
display_process.start()
# Set pipeline to PLAYING state
self.pipeline.set_state(Gst.State.PLAYING)
# dump dot file
GLib.timeout_add_seconds(3, self.dump_dot_file)
# Run the GLib event loop
try:
self.loop.run()
except:
pass
# Clean up
self.lss_data.running = False
self.pipeline.set_state(Gst.State.NULL)
display_process.terminate()
display_process.join()
# User defined callback function
def lss_callback(pad, info, lss_data):
print(f"lss_data id: {id(lss_data)}")
print(f"lss_data.use_frame: {lss_data.use_frame}")
buffer = info.get_buffer()
if buffer is None:
return Gst.PadProbeReturn.OK
print(f"width: {width}")
print(f"height: {height}")
# from omria in hailo moderator
if not format or not width or not height:
print("Error: Format, width, or height not retrieved from pad caps.")
string_to_print = f"Frame count: {lss_data.get_count()}\n"
frame = None # Initialize frame to None
if lss_data.use_frame and format and width and height:
print(f"Frame shape: {frame.shape}")
else:
print("Failed to convert buffer to NumPy array.")
# if frame is None:
# print("Failed to get frame from buffer.")
# # print(f"Frame shape: {frame.shape}")
# else:
else:
print("Frame not retrieved due to missing format or dimensions.")
detection_count = 0
# for detection in detections:
# label = detection.get_label()
# bbox = detection.get_bbox()
# confidence = detection.get_confidence()
# print(f"label: {label}, bbox: {bbox}, confidence: {confidence}")
# if label != "JJH" and lss_data.use_frame:
# frame = lss_data.get_frame()
# if frame is not None:
# cv2.rectangle(frame, (int(bbox.xmin()), int(bbox.ymin())), (int(bbox.xmax()), int(bbox.ymax())), (0, 255, 0), 2)
# x1_norm = bbox.xmin()
# y1_norm = bbox.ymin()
# x2_norm = bbox.xmax()
# y2_norm = bbox.ymax()
# x1 = int(x1_norm * width)
# y1 = int(y1_norm * height)
# x2 = int(x2_norm * width)
# y2 = int(y2_norm * height)
# okay_bbox = (x1, y1, x2 - x1, y2 - y1)
# string_to_print += f"Detection {detection_count}: Label = {label}, BBox = {okay_bbox}, Confidence = {confidence:.2f}\n"
# detection_count += 1
# output_dir = '/opt/iot/results'
# os.makedirs(output_dir, exist_ok=True)
# output_path = os.path.join(output_dir, f"frame_{lss_data.get_count()}.jpg")
# cv2.imwrite(output_path, cv2.cvtColor(frame, cv2.COLOR_RGB2BGR))
# print(f"Saved frame to {output_path}")
cv2.rectangle(
frame,
(0, 255, 0),
cv2.putText(
frame,
f"{label}: {confidence:.2f}",
(int(bbox.xmin()), int(bbox.ymin()) - 10),
0.5,
(0, 255, 0),
if detection_count > 0:
string_to_print += f"Total detections: {detection_count}\n"
if lss_data.use_frame and frame is not None:
lss_data.set_frame(frame)
cv2.putText(frame, "Custom Text", (50, 50), cv2.FONT_HERSHEY_SIMPLEX, 1, (255, 0, 0), 2)
cv2.circle(frame, (width // 2, height // 2), 30, (0, 255, 255), 3)
print(string_to_print)
# User Gstreamer Application
def __init__(self, args, lss_data):
super().__init__(args, lss_data)
self.batch_size = 2
self.default_postprocess_so = os.path.join(self.postprocess_dir, 'libyolo_hailortpp_post.so')
# self.thresholds_str = "" # Initialize thresholds_str as empty string
if args.network == "yolov6n":
self.hef_path = os.path.join(self.current_path, './hailomodel/yolov6n.hef')
elif args.network == "yolov8s":
self.hef_path = os.path.join(self.current_path, './hailomodel/yolov8s_h8l.hef')
elif args.network == "yolov8n":
nms_score_threshold = 0.1
nms_iou_threshold = 0.1
# nms_score_threshold = 0.3
# nms_iou_threshold = 0.45
self.thresholds_str = f"nms-score-threshold={nms_score_threshold} nms-iou-threshold={nms_iou_threshold} output-format-type=HAILO_FORMAT_TYPE_FLOAT32"
self.hef_path = os.path.join(self.current_path, './hailomodel/eeg_employee_2.hef')
elif args.network == "yolox_s_leaky":
self.hef_path = os.path.join(self.current_path, './hailomodel/yolox_s_leaky_h8l_mz.hef')
else:
assert False, "Invalid network type"
setproctitle.setproctitle("Hailo Detection App")
self.create_pipeline()
if (self.source_type == "rpi"):
source_element = f"libcamerasrc name=src_0 auto-focus-mode=2 ! "
source_element += f"video/x-raw, format={self.network_format}, width=1536, height=864 ! "
source_element += QUEUE("queue_src_scale")
source_element += f"videoscale ! "
source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
elif (self.source_type == "usb"):
# source_element = f"v4l2src device={self.video_source} name=src_0 ! "
# source_element += f"video/x-raw, width=640, height=480, framerate=30/1 ! "
# # from omria in hailo moderator
# source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
# # source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, framerate=5/1 ! "
# # source_element += f"video/x-raw, format={'YUYV'}, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
# Use JPEG encoding and specify resolution and framerate
source_element += f"image/jpeg, width={self.network_width}, height={self.network_height}, framerate=30/1 ! "
source_element += f"jpegdec ! " # Decode JPEG back to raw video
source_element += f"video/x-raw, format={self.network_format} ! " # Ensure correct format after decoding
else:
source_element = f"filesrc location={self.video_source} name=src_0 ! "
source_element += QUEUE("queue_dec264")
source_element += f" qtdemux ! h264parse ! avdec_h264 max-threads=2 ! "
source_element += f" video/x-raw,format=I420 ! "
source_element += QUEUE("queue_scale")
source_element += f" videoscale n-threads=2 ! "
source_element += QUEUE("queue_src_convert")
source_element += f" videoconvert n-threads=3 name=src_convert qos=false ! "
source_element += f"video/x-raw, format={self.network_format}, width={self.network_width}, height={self.network_height}, pixel-aspect-ratio=1/1 ! "
pipeline_string = "hailomuxer name=hmux "
pipeline_string += source_element
pipeline_string += "tee name=t ! "
pipeline_string += QUEUE("bypass_queue", max_size_buffers=20) + "hmux.sink_0 "
pipeline_string += "t. ! " + QUEUE("queue_hailonet")
pipeline_string += "videoconvert n-threads=3 ! "
pipeline_string += f"capsfilter caps=\"video/x-raw,format=RGB,width={self.network_width},height={self.network_height}\" ! "
pipeline_string += f"hailonet hef-path={self.hef_path} batch-size={self.batch_size} {self.thresholds_str} force-writable=true ! "
pipeline_string += QUEUE("queue_hailofilter")
self.json_config_path = "./resource/eeg_employee_2.json"
pipeline_string += f"hailofilter function-name=\"filter\" so-path={self.default_postprocess_so} config-path={self.json_config_path} qos=false ! "
pipeline_string += QUEUE("queue_hmuc") + " hmux.sink_1 "
pipeline_string += "hmux. ! " + QUEUE("queue_hailo_python")
pipeline_string += QUEUE("queue_user_callback")
pipeline_string += f"identity name=identity_callback ! "
pipeline_string += QUEUE("queue_hailooverlay")
pipeline_string += f"hailooverlay ! "
pipeline_string += QUEUE("queue_videoconvert")
pipeline_string += f"videoconvert n-threads=3 qos=false ! "
pipeline_string += QUEUE("queue_hailo_display")
pipeline_string += f"fpsdisplaysink video-sink={self.video_sink} name=hailo_display sync={self.sync} text-overlay={self.options_menu.show_fps} signal-fps-measurements=true "
return pipeline_string
if __name__ == "__main__":
parser = get_default_parser()
# Add additional arguments here
parser.add_argument("--network", default="yolov8n", choices=['yolov6n', 'yolov8s', 'yolox_s_leaky'],
help="Which Network to use, defult is yolov6n")
args = parser.parse_args()
lss_data = lss_callback_class()
# app = GStreamerDetectionApp(args, user_data)
app = GStreamerDetectionApp(args, lss_data)
print("Starting GStreamerDetectionApp")
begin = time.time()
app.run()
print("Application run completed")
end = time.time()
print("Total time: ", 733 / (end - begin))
