Do you recommend Hailo10 for a LightGLue model
Hello Hailo community,
I am currently working on compiling a custom LightGlue model (transformer-based image matching with self and cross-attention blocks). I am currently targeting the Hailo-8, but I am wondering if compiling this model will be easier and run significantly faster on the Hailo-10H.
I know there is no official recipe for LightGlue in the Model Zoo yet, but I would appreciate some technical opinions on this.
Since Hailo-10H is explicitly advertised for GenAI applications, I assume its architecture is better suited for the heavy matrix multiplications and attention mechanisms found in LightGlue.
If so, what are the concrete hardware or software compiler advantages of Hailo-10H over Hailo-8 for a model like this? Specifically:
  • Hardware support for operations: Does the 10H have native/better acceleration for Operations like BatchMatMul, Softmax, and LayerNorm, which are typically tricky to quantize and compile efficiently on Hailo-8?
  • Memory hierarchy: Does the dedicated DDR memory on the 10H help alleviate the SRAM bottlenecks caused by $N \times N$ attention activation maps, rather than just storing larger weights?
  • Compiler maturity: Is the Hailo Dataflow Compiler inherently better equipped to map Transformer graphs to the 10H without requiring as many manual graph splits or workarounds?
Thanks in advance for any insights!
Maybe these will help:
Michael.
