Hi. I am running the detection example from hailo-apps-infra repository. I ran the following code but no text are showing in the live frames, only the object label, bounding box, confidence and ID are shown. May I know what is missing from the code?
# Third-party imports
import gi
from gi.repository import Gst
import cv2
# Local application-specific imports
import hailo
from hailo_apps.hailo_app_python.core.common.buffer_utils import get_caps_from_pad, get_numpy_from_buffer
from hailo_apps.hailo_app_python.core.gstreamer.gstreamer_app import app_callback_class
from hailo_apps.hailo_app_python.apps.detection.detection_pipeline import GStreamerDetectionApp
# endregion imports
# User-defined class to be used in the callback function
# Inheritance from the app_callback_class
def __init__(self):
super().__init__()
self.video_width = 640
self.video_height = 480
# User-defined callback function
# This is the callback function that will be called when data is available from the pipeline
buffer = info.get_buffer()
if buffer is None:
return Gst.PadProbeReturn.OK
# Using the user_data to count the number of frames
user_data.increment()
string_to_print = f"Frame count: {user_data.get_count()}\n"
# Get the caps from the pad
# If the user_data.use_frame is set to True, we can get the video frame from the buffer
frame = None
detection_count = 0
for detection in detections:
label = detection.get_label()
bbox = detection.get_bbox()
if label == "person":
track_id = 0
track = detection.get_objects_typed(hailo.HAILO_UNIQUE_ID)
if len(track) == 1:
track_id = track[0].get_id()
string_to_print += (f"Detection: ID: {track_id} Label: {label} Confidence: {confidence:.2f}\n")
detection_count += 1
if user_data.use_frame:
user_data.set_frame(frame)
#print(string_to_print)
if __name__ == "__main__":
# Create an instance of the user app callback class
app.run()
