Hey,
after successfully parsing my ONNX model, I’ve tried to optimize it and recieved this error message:
hailo_sdk_common.hailo_nn.exceptions.UnsupportedModelError: Invalid kernel shape for dense layer best_mae_convnext_tiny_ucf_simp_is/fc1 (translated from /backbone/features.1/features.1.0/block/block.2/LayerNormalization). Kernel input features: 96, Input features: 11796480
After this I looked into the har file and noticed that there is a mismatch in output and input dimensions:
"best_mae_convnext_tiny_jhu_simp_is/normalization2": {
"type": "normalization",
"input": ["best_mae_convnext_tiny_jhu_simp_is/layer_normalization2"],
"output": ["best_mae_convnext_tiny_jhu_simp_is/fc1"],
"input_shapes": [[-1, 256, 480, 96]],
"output_shapes": [[-1, 256, 480, 96]],
"original_names": ["/backbone/features.1/features.1.0/block/block.2/LayerNormalization"],
"compilation_params": {},
"quantization_params": {},
"params": {
"elementwise_add": false,
"activation": "linear"
"best_mae_convnext_tiny_jhu_simp_is/fc1": {
"type": "dense",
"input": ["best_mae_convnext_tiny_jhu_simp_is/normalization2"],
"output": ["best_mae_convnext_tiny_jhu_simp_is/fc2"],
"input_shapes": [[-1, 1, 1, 11796480]],
"output_shapes": [[-1, 1, 1, 384]],
"original_names": ["/backbone/features.1/features.1.0/block/block.3/MatMul", "/backbone/features.1/features.1.0/block/block.3/Add", "/backbone/feat>
"params": {
"kernel_shape": [96, 384],
"batch_norm": false,
"activation": "gelu"
I’ve tried to resolve this by adding this to my modelscript:
pre_quantization_optimization(defuse, layers=fc1, num_splits=96, defuse_type=INPUT_FEATURES)
This produced the following error message:
File "/venv/bin/hailo", line 8, in <module>
sys.exit(main())
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/main.py", line 111, in main
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 68, in run
return self._run(argv)
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/tools/cmd_utils/base_utils.py", line 89, in _run
return args.func(args)
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/tools/optimize_cli.py", line 113, in run
self._runner.optimize_full_precision(calib_data=dataset)
File "/venv/lib/python3.10/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2031, in optimize_full_precision
self._optimize_full_precision(calib_data=calib_data, data_type=data_type)
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/runner/client_runner.py", line 2034, in _optimize_full_precision
self._sdk_backend.optimize_full_precision(calib_data=calib_data, data_type=data_type)
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1602, in optimize_full_precision
model, params = self._run_post_fuser(model, params, update_model_and_params)
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/sdk_backend/sdk_backend.py", line 1648, in _run_post_fuser
post_fuser.run()
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/post_fuser/post_fuser.py", line 76, in run
self._model = algo.run()
File "/venv/lib/python3.10/site-packages/hailo_model_optimization/algorithms/algorithm_base.py", line 150, in run
self._run_int()
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/post_fuser/algorithms/input_features_defuse.py", line 26, in _run_int
act_dict = self._defuse_input_features()
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/post_fuser/algorithms/input_features_defuse.py", line 158, in _defuse_input_features
self._move_fused_slice_params(
File "/venv/lib/python3.10/site-packages/hailo_sdk_client/post_fuser/algorithms/fuser_algorithm.py", line 66, in _move_fused_slice_params
reshaped_src_kernel = src_kernel.reshape(pred_output_shape[1:] + [f_out])
ValueError: cannot reshape array of size 36864 into shape (256,480,96,384)
The relevant section looks like this in netron:
I’m not sure what to do at this point.
Thank you for your help in advance.
