Cannot achieve fullscreen output with GStreamer sinks on Raspberry Pi 5
I have tried many times to enable fullscreen display for the output of a real-time segmentation app using GStreamer on Raspberry Pi 5. I have used all available community suggestions including:
  • xvimagesink fullscreen=true
  • glimagesink, gtksink, and even appsink
  • Manual window resizing, gtk_widget_set_fullscreen(), and related API calls
  • Running with or without X11, on Wayland and via direct framebuffer
None of these methods actually display the video in fullscreen — even manually maximizing the window does not work.
Could you please provide a minimal working example that shows how to launch a GStreamer-based video output in actual fullscreen (not just maximized window) on Raspberry Pi 5?
Thank you very much!
Hey @Chin_Hsu ,
You’ll need to update the DISPLAY_PIPELINE call in your pipeline code.
Instead of using the default video sink, change it to this:
display_pipeline = DISPLAY_PIPELINE(
    video_sink="kmssink fullscreen=true",  # This replaces self.video_sink
    sync=self.sync,
    show_fps=self.show_fps,
You have a few different sinks to choose from:
  1. KMS Sink (this is your best bet for Pi 5): kmssink fullscreen=true
  2. Wayland Sink: waylandsink fullscreen=true
Thanks for sharing. I’m using Wayland mode and have tried waylandsink fullscreen=true. I also tried video_sink="kmssink fullscreen=true".
However, I encountered the following error:
Error creating pipeline: gst_parse_error: no property “fullscreen” in element “fpsdisplaysink”.
this can be fullscreen.
/home/pi/hailo-rpi5-examples/venv_hailo_rpi_examples/lib/python3.11/site-packages/hailo_apps/hailo_app_python/apps/instance_segmentation/instance_segmentation_pipeline.py
Set process title for easy identification
setproctitle.setproctitle(INSTANCE_SEGMENTATION_APP_TITLE)
Force fullscreen display using waylandsink
self.video_sink = ‘fpsdisplaysink video-sink=“waylandsink fullscreen=true” sync=false’
Build the GStreamer pipeline
self.create_pipeline()
moreover, modify
self.video_width = 1280
self.video_height = 720
