I want to integrate a simple hardware-existance check in my program.
The following code works, but HailoRT generates output on std err even when using export HAILORT_LOGGER_PATH=NONE
int verifyHailo8()
int hail8Present = 1;
auto result = hailort::VDevice::create();
if (!result.has_value())
hail8Present = 0;
return hail8Present;
[HailoRT] [error] CHECK failed - Failed to create vdevice. there are not enough free devices. requested: 1, found: 0
[HailoRT] [error] CHECK_SUCCESS failed with status=HAILO_OUT_OF_PHYSICAL_DEVICES(74)
Hailo 8 present 0
I could start the program with ./program 2> /dev/null
and effectively get the result I want, but I was wondering is there is a way to turn off stderr from HailoRT.
I could not find any logging API function to handle this.
Working on HailoRT 4.20.
Thanks.
