All roads lead to?
I am not an IT guy, or a programmer. I do like to tinker with new technology. I have a home LAN server, running from a Beelink SER8 (8845HS), on Ubuntu Server (which I am using the Hailo-8 on), and a RPI5, running HAOS. I bought the Hailo-8 to help run Frigate for my home cameras, and maybe give my Beelink a bump in performance with Ollama as well. I hadn’t made an account here, yet, so I ignorantly assumed that Hailo-8 was something I installed the firmware on, and then it ran like a graphics card or something. I have managed to install the firmware, and I have a docker container of the Suite running. Now, I am kind of lost from there. Reading through random threads, I have noticed that things need to get converted to .ref (can’t remember if that is correct) files, and then stuff will work, or something.
I am not seeing an “A to Z” guide anywhere, like one might find in a textbook. Am I missing a big red button that says, “Start Here?” It would be like a Wiki, or a book (I’ll gladly buy it), which shows an overview of how everything works. Then the first steps, in a bunch of ways (depending on the hardware and OS) of the installation of the firmware and suite. Then, examples of uses with the Suite (internal). Finally, how to get things to work with external stuff, like Frigate and Ollama. But, all in one book, Wiki, etc.
This is certainly my fault. I get that many people are able to figure things out this way. I am just curious if there is a more traditional approach. I love the idea of this Hailo Project, by the way.
While there are textbooks about machine learning, neural networks and other related topic I am afraid I have not seen an “all in one book”.
To get started with Hailo I recommend playing with the example application from Raspberry and Hailo first:
GitHub - Hailo RPi5 Examples
And then take it from there depending of your interests. e.g. retrain a supported model and convert it using the Hailo Model Zoo hailomz command.
GitHub - Hailo Model Zoo - Retrain on custom dataset
If you want to understand how to convert your own models start with the Hailo AI Software Suite Docker built in tutorials. Inside the Docker call:
hailo tutorial
For general questions about AI, training models, datasets, Python … , Chat GPT is a great tool.
