HailoRT NMS support is only available for a subset of models. You can find the post-processing configuration files for supported models in the Hailo Model Zoo:
GitHub - Hailo Model Zoo - Postprocess Config Files
The yolov8m_seg model does not currently include NMS support.
For models without built-in NMS support, post-processing must be performed in the host application. Hailo provides example implementations for many supported models. For custom models, you may need to implement the required post-processing logic yourself as part of the model deployment workflow.
For yolov8m_seg , you can refer to the following examples in the Hailo Apps repository:
Python (Instance Segmentation):
GitHub - hailo-apps - Python - Instance Segmentation
C++ (Instance Segmentation):
GitHub - hailo-apps - CPP - Instance Segmentation
Alternatively you can also download and parse the pre-compiled HEF files from our Model Zoo GitHub repository.
Use the hailortcli parse-hef model.hef command.
The output for a model with NMS will look like this (yolov8m):
HEF Compatible for: HAILO8
Network group name: yolov8m, Multi Context - Number of contexts: 3
Network name: yolov8m/yolov8m
VStream infos:
Input yolov8m/input_layer1 UINT8, NHWC(640x640x3)
Output yolov8m/yolov8_nms_postprocess FLOAT32, HAILO NMS BY CLASS(number of classes: 80, maximum bounding boxes per class: 100, maximum frame size: 160320)
Operation:
Op YOLOV8
Score threshold: 0.200
IoU threshold: 0.70
Classes: 80
Max bboxes per class: 100
Image height: 640
Image width: 640
All other models e.g. yolov8m_seg will show raw output layers:
Network group name: yolov8m_seg, Multi Context - Number of contexts: 3
Network name: yolov8m_seg/yolov8m_seg
VStream infos:
Input yolov8m_seg/input_layer1 UINT8, NHWC(640x640x3)
Output yolov8m_seg/conv93 UINT8, NHWC(20x20x64)
Output yolov8m_seg/conv94 UINT8, NHWC(20x20x80)
Output yolov8m_seg/conv95 UINT8, NHWC(20x20x32)
Output yolov8m_seg/conv78 UINT8, FCR(40x40x64)
Output yolov8m_seg/conv79 UINT8, FCR(40x40x80)
Output yolov8m_seg/conv80 UINT8, FCR(40x40x32)
Output yolov8m_seg/conv60 UINT8, FCR(80x80x64)
Output yolov8m_seg/conv61 UINT8, FCR(80x80x80)
Output yolov8m_seg/conv62 UINT8, FCR(80x80x32)
Output yolov8m_seg/conv64 UINT8, FCR(160x160x32)
