I am using my hailo-8L with frigate in home assistant and I downloaded the yolov11s model which is impressively accurate also at night. Anyway inference time is around 26 ms, which is a bit high. The model is compiled at 640x640 and it would be beneficial to have it at 320x320 (which is also the size suggested in Frigate docs). Is there a place from which I can download yolov11s model compiled at 320x320?
thank you in advance
Cristiano
P.S. I have a macos laptop and I can’t not make hailo software suite work to build the .hef file myself
Unfortunately Hailo doesn’t currently provide pre-compiled YOLOv11s HEF files at 320x320 - the Model Zoo only ships 640x640 variants.
To get a 320x320 HEF you’d need to compile it yourself using the Hailo Dataflow Compiler (DFC) with something like hailomz compile yolov11s --hw-arch hailo8l --resize 320 320 , which does require an x86_64 Linux environment.
Since you’re on macOS, you might try running the DFC inside a Docker container Convert Ultralytics yolov8n.pt to yolov8n.hef fails.
Alternatively, as a quicker workaround to reduce inference time without recompiling, you might try switching to yolov11n (the nano variant) at 640x640, which should be noticeably faster on the 8L while still providing reasonable accuracy for most Frigate use cases.
Dear Michael,
I would like to stick to yolov11s because it is significantly more accurate
than n variant night time. I do have access to a linux machine, in order to execute
hailomz, do I need to install the whole hailo software suite on this linux machine?
What file do I have to supply to hailomz? Sorry for the silly question but I am newbie to this,
The easiest path might be to install the full suite since it bundles everything together and ensures version compatibility, but if you prefer a lighter setup, you could install just the DFC and the Model Zoo. Here’s roughly what you’d do on your Linux machine:
Go to https://hailo.ai/developer-zone/sw-downloads/ and download the Dataflow Compiler wheel file (for Hailo-8L, you’d want the v3.x branch — currently v3.33.0). You might need to create a free Hailo developer account if you don’t have one.
Clone and install the Model Zoo (use the v2.x branch for Hailo-8L):
git clone https://github.com/hailo-ai/hailo_model_zoo.git
cd hailo_model_zoo
pip install -e .
You’ll also need a folder of calibration images (typically ~64 images from COCO val2017 or similar should work). The Model Zoo might handle downloading the ONNX checkpoint for yolov11s automatically, but if not, you can export it from Ultralytics with yolo export model=yolov11s.pt format=onnx imgsz=320.
Regarding the 320x320 input size - you might need to modify the model’s YAML config in the Model Zoo (hailo_model_zoo/cfg/networks/yolov11s.yaml) to change the input resolution from 640 to 320, or export the ONNX at 320x320 and supply it via --ckpt ./yolov11s_320.onnx. The system requirements are Ubuntu 22.04/24.04 x86_64 with 16+ GB RAM - a GPU is helpful for the optimization step (faster) but the process can run on CPU only, just slower and with a warning about reduced optimization.
yolo26s is much slower than yolov11s but of course if I will be able to recompile these models at 320x320 I will give it a try, thank you for pointing it out,
I did installation steps and everything went fine until I issued the command
pip install -e .
which gives me
× Getting requirements to build editable did not run successfully.
│ exit code: 1
╰─> [26 lines of output]
File “/home/demichel/HAILO/hailo_venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 389, in
main()
File “/home/demichel/HAILO/hailo_venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 373, in main
json_out[“return_val”] = hook(**hook_input[“kwargs”])
File “/home/demichel/HAILO/hailo_venv/lib/python3.12/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py”, line 157, in get_requires_for_build_editable
return hook(config_settings)
File “/tmp/pip-build-env-fy3_2upn/overlay/lib/python3.12/site-packages/setuptools/build_meta.py”, line 481, in get_requires_for_build_editable
return self.get_requires_for_build_wheel(config_settings)
File “/tmp/pip-build-env-fy3_2upn/overlay/lib/python3.12/site-packages/setuptools/build_meta.py”, line 333, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=)
File “/tmp/pip-build-env-fy3_2upn/overlay/lib/python3.12/site-packages/setuptools/build_meta.py”, line 301, in _get_build_requires
self.run_setup()
File “/tmp/pip-build-env-fy3_2upn/overlay/lib/python3.12/site-packages/setuptools/build_meta.py”, line 520, in run_setup
super().run_setup(setup_script=setup_script)
File “/tmp/pip-build-env-fy3_2upn/overlay/lib/python3.12/site-packages/setuptools/build_meta.py”, line 317, in run_setup
exec(code, locals())
File “”, line 19, in
importlib.metadata.PackageNotFoundError: No package metadata was found for
The Dataflow Compiler package ‘hailo-dataflow-compiler’ was not found.
Please verify working in the correct virtualenv.
If you are not an Hailo customer, please visit us at https://hailo.ai/
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed to build ‘file:///home/demichel/HAILO/hailo_model_zoo’ when getting requirements to build editable
regarding my previous post, issue was that I was not using python 3.10, moreover I discovered that with hailo model zoo v2.18 there is a bug which prevents compilation but switching to v2.17 fixes the problem, now I am finally compiled yolov11s at 320x320
and it works in frigate with an impressive inference time of 12 ms,
Now, if I want to recompile also yolo26s at 320 to make it work in frigate, what I have to do?
Hi @Cristiano_De_Michele, Sorry about the confusion. I edited my previous reply. Accuracy shouldn’t be lost, it’s just GPU is helpful for the optimization step (faster).
concerning the procuder to get model at 320,
if one does not use the file onnx exported at 320, the internal resolution of the model
remains at 640 and inference speed is identical to the model compiled at 640.
Hence I think it is necessary to export the model at 320 from ultralytics at 320
by the command:
To have a fine-tuned for quantization I used google colab (using the A100 GPU runtime) to generate the .har file and then I used locally the .har file on WSL by using the following command:
We do have plans to update soon our versions for both Home Assistant and Frigate - generally and the Home Assistant Addon (app).
We definitely will consider than Yolo26.
