why is the new one of hailo-rpi5-examples NOT backward compatible ?????
this is not good practice to not be backward compatible.
#!/bin/bash
. setup_env.sh
#hailopipe/hailopipe &
hailocmdbox/build-hailocmdbox-Desktop-Release/Qthailopipe &
python3 basic_pipelines/madsen2.py --hef-path local_resources/yolov11s.hef --input rpi --show-fps >> /tmp/hailo
rm /tmp/hailo
yolov11s.hef didnot exits anymore what to usu instead.
Waste of my time.
for the user using my small aps this is the new madsen.py
from pathlib import Path
import gi
gi.require_version(‘Gst’, ‘1.0’)
import os
import cv2
import hailo
from hailo_apps.hailo_app_python.core.common.buffer_utils import get_caps_from_pad, get_numpy_from_buffer
from hailo_apps.hailo_app_python.core.gstreamer.gstreamer_app import app_callback_class
from hailo_apps.hailo_app_python.apps.detection.detection_pipeline import GStreamerDetectionApp
User-defined class to be used in the callback function
def init(self):
super().init()
self.new_variable = 42 # New variable example
def new_function(self):  # New function example
    return "The meaning of life is: "
User-defined callback function
buffer = info.get_buffer()
if buffer is None:
return Gst.PadProbeReturn.OK
user_data.increment()
string_to_print = f"Frame count: {user_data.get_count()}\n"
frame = None
detection_count = 0
for detection in detections:
    label = detection.get_label()
    bbox = detection.get_bbox()
    if label:
        # Get track ID
        track_id = 0
        track = detection.get_objects_typed(hailo.HAILO_UNIQUE_ID)
        if len(track) == 1:
            track_id = track[0].get_id()
        string_to_print += (f"Detection: ID: {track_id} Label: {label} Confidence: {confidence:.2f}\n")
        detection_count += 1
        if user_data.use_frame and frame is not None:
            x_min = bbox.xmin()
            y_min = bbox.ymin()
            box_width = bbox.width()
            box_height = bbox.height()
            x_max = x_min + box_width
            y_max = y_min + box_height
            cv2.rectangle(
                frame,
                (int(x_min * width), int(y_min * height)),
                (int(x_max * width), int(y_max * height)),
                (255, 255, 255),
                1,
            cv2.putText(
                frame,
                label,
                (int(x_min * width), int(y_min * height) - 10),
                cv2.FONT_HERSHEY_SIMPLEX,
                1,
                (255, 255, 255),
                1,
    cv2.putText(frame, f"{user_data.new_function()} {user_data.new_variable}", (10, 60), cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2)
    user_data.set_frame(frame)
print(string_to_print)
if name == “main”:
project_root = Path(file).resolve().parent.parent
env_file = project_root / “.env”
env_path_str = str(env_file)
os.environ[“HAILO_ENV_FILE”] = env_path_str
app.run()
Hey @Kim_Madsen,
Thank you for raising this concern, and I understand your frustration with the current compatibility issues.
I wanted to provide you with an update on our roadmap: We are currently preparing for a migration to version 4.22, which will include several important updates and improvements. The current challenge you’re experiencing stems from the fact that models compiled with DFC 3.32 are not compatible with HailoRT 4.20.
Once we complete the transition to version 4.22, we will be implementing backward compatibility measures to prevent similar issues in future releases.
We appreciate your patience during this transition period, and I’ll make sure to keep the community updated on our progress toward the 4.22 release.
Ok just a little brag I just let copilot change the code again :slight_smile:
AI is not a bad thing :rofl:
