Hi.
I am trying to switch from Nvidia to Hailo and having few confusion
I just want to detect one object [example only car ]
when I am doing it, the program open a new window [User Frame]- which I think is unnecessary and also resource consuming and this new window is not projecting in full screen and few buttons are always on top.
I am unable to find any documentation
any way to run ultracytics over hailo ?
any help well be appreciated
thanks
Hey @sham,
Regarding the user frame - this is intended for writing on top of frames in Python and cannot be executed directly. Please do not use the --user-frame flag.
We have compiled most YOLO models in our model zoo with straightforward compilation procedures. You can access them at: GitHub - hailo-ai/hailo_model_zoo: The Hailo Model Zoo includes pre-trained models and a full building and evaluation environment
For single object detection, you can modify the labels JSON file accordingly.
Dear Omria
Greetings
the issue is not of detection but of the primary window.
i can not change or add the logic in the primary window and if i have to
add my logic in the window then a new window appear
that to never in the centre and with lots of button on the top.
cant we just add our own bounding box logic on the main window ?
thanks
Hi.
great, i will not use --user-frame flag.
the issue is - how to make basic changes
like instead of square box i want circle
or i want filled box or any other info on top of box
where is the sample code for these kind of things.
i havent found any code to write any thing
thanks
Hey @sham,
I see what you’re trying to do - you want to add custom drawing on top of the video frames, right?
Unfortunately, this isn’t as straightforward as it should be with our current setup. The main display window you see when running HailoRT CLI is controlled by the hailooverlay GStreamer element. There’s no Python hook into that window, so you can’t directly add your own drawings like circles or custom labels without modifying the plugin source code.
Good news is we’re working on making this easier in future releases.
For now, you’ve got a few workarounds:
Option 1: Separate window approach
Use a user-frame callback to grab the frame data, do your OpenCV drawing, then display it in your own window alongside the main one.
Option 2: Custom pipeline
Write your own Python/GStreamer script that skips the hailooverlay entirely. Use the same pipeline elements but pull frames back to Python for custom drawing, then show with cv2.imshow.
Option 3: Overlay on overlay
Create your own overlay with the Python drawing you want and pipe it after the hailooverlay element.
The user-frame callback (Option 1) is probably your quickest path if you don’t mind having two windows open.
If you want to dig deeper into the source, check out hailo-tappas-core where these plugins live.
Thanks Omria
for your response
i am using user-frame but there is a fairly good amount of delay -
[lagging]
of around 2 -3 seconds
for other two options can you plesase send some link
Thanks
Hey @sham,
For option 2, we don’t actually have an example like that available. But basically, you’d be handling the drawing of the boxes and any other graphics you want through your own overlay implementation.
As for option 3, I’ve personally tried using cairooverlay right after hailooverlay and it worked pretty well for me - I was able to write text and draw on the frames without any issues.
Just a heads up though - we’re currently working on developing a better way to handle this, so keep an eye out for updates!
Hope that helps clarify things!
hi
me again
i have tried all resources and unable to install or find
hailo_apps_info
i have to use hailo_rpi_comon
checked every single loation on github
Please help
thanks
Hey @sham ,
Please use the install.sh in here :
done it so many times
even with the fresh installation
always getting No module named hailo_apps_infra
asking this question from ages still no solution ![]()
software is not well documented
I have a simple task
to make the circle instead of bounding box i have to make different kind of box depending of detected object -
and seems there is no way to do this .
Ultralytics yolo gives a better way to draw using cv2 - but ultralytics cant use your hailo
As for option 3
- Can you share how your pipeline string with cairooverlay will be look like?
- How can I attach my own python class to new cairooverlay pipe? Can you share example?
