Whole-body EMG + IMU to pose: is our model plan sensible before we record?
Hi, we are designing a neural suit, still on paper: 128 differential sEMG channels (ADS1299,
16 modules) and 48 IMUs over the whole body, plus 40 IMUs in two gloves, a computer in the
backpack and a Hailo-10H for the model. Goal: the body’s movement (127 joint values) and
contacts at 120 Hz, as a controller first and for rehabilitation second. Before we record
anything, we’d like to hear from people who have modelled EMG whether our plan makes sense.
What we planned:
  • Features, not raw EMG: per 1/120 s step, a log-RMS envelope per channel (10 Hz high-pass
    first), plus each IMU’s step (Δθ and mean force, 6 values). 512 values a step.
  • A window of 32 steps (267 ms), a temporal convolutional network (1 × k over time, 1 × 1 across
    channels), INT8, no recurrence or attention (it has to run on the Hailo and on the RK3588’s
    NPU).
  • Labels without labelling: joint angles from the IMUs are the target for the EMG part, so the
    EMG learns to see a movement coming before it shows in the IMUs.
  • A split model: a large fixed part trained on many recordings, a small last part that learns
    this person and this fit of the suit on the CPU while it is worn.
Questions:
  1. Would you start from a temporal CNN for this, or from something else? What worked for you?
  2. What do we lose with log-RMS envelopes only, against spectral features or raw EMG?
  3. IMU-derived angles as the EMG’s target: sensible? Pitfalls (drift, the EMG leading the
    movement by tens of ms)?
  4. The suit sits a little differently every time it is put on. emg2pose found that generalising
    across users and placements needs many of both; with one wearer and a small personal part,
    how much calibration should we expect after each donning?
  5. Is 267 ms a reasonable window, or too short or too long?
The design is public: GitHub - Project-NIC/NIC-Crazy_Ivan: A neural suit, a design-stage concept: 128–256 EMG electrodes (ADS1299) and IMUs on a suit made of pieces, a computer in the backpack, the whole body as a controller. Nothing built yet. · GitHub (the signals and the model
are in bata/SIGNALS.md and bata/SOFTWARE.md).
Thanks!
This is a highly ambitious project. I assume you’d run searches to find what others have done in this area but my guess is that others focus on smaller and therefore more managable problems. You might run the software model in Matlab first with previously recorded data, before dealing with the added complexity of acuiring the data and processing it on the RPi in real-time. Keep working on this, it is impressive.
Thanks, Gabor, good advice, and we’ll take it: the model gets tried offline on recorded data first, before anything runs in real time. Until our own recordings exist, a public set such as Meta’s emg2pose (a 16-channel sEMG wristband with hand poses from motion capture) is the obvious place to test the temporal CNN and the log-RMS features. Where the design is now: 280 differential channels on ADS1298, 108 IMUs (48 of them in the gloves), a Radxa ROCK 5T in the backpack, the Hailo-10H an option. If anyone has tried a TCN on emg2pose or something like it, I’d still be glad to hear what worked.
