Where can we find the Qwen2.5-1.5B-Instruct HAR?
I can see the HAR file for the Qwen2-1.5B-Instruct under the GenAI model page, but the Qwen2.5 only has the HEF available for download. Is someone available to provide the HAR? DFC documentation points to the model zoo github repo for the HAR files, but it doesn’t contain the models or HAR files
Hi @bill_bz ,
Can you please provide the exact links you are referring to?
Absolutely.
The Qwen2.5 1.5b model page is here: Qwen2.5 1.5B: GenAI Large Language Model | Hailo Edge AI - this has the HEF file, but not the HAR file; whereas the Qwen 2 1.5b page has both the HEF and the HAR file. The LoRA documentation does state that the HAR file is available, but the download link isn’t posted, and I cannot find it anywhere.
The DataCompiler documentation points to the model zoo Github repo to obtain the pre-optimized model, but the repo only contains the model manifests.
Qwen2 1.5b download page: Qwen2 1.5B: Large Language Model | Hailo Edge AI
Model Zoo GH repo: hailo_model_zoo_genai/models/manifests at main · hailo-ai/hailo_model_zoo_genai · GitHub
Dataflow Compiler Docs: https://hailo.ai/developer-zone/documentation/dataflow-compiler-v5-2-0/?sp_referrer=_images/genai_workflow.svg
Hi @bill_bz ,
We released HAR only for the LoRA model.
I’m not too sure what you mean - you have a LoRA tutorial that uses the Qwen2 1.5b as an example - is that the only one on which you allow LoRA?
I would really like to use Qwen2.5 as the model to fine tune, is there any method by which I can get that HAR file from you?
Hi @bill_bz ,
Yes - that’s right.
