What can be done with Hailo 8L ?
What can be done with Hailo 8L? For example, can I download and use text-based AI? Or can I create a visual?
Hey @ast_45_45, welcome to the community!
The Hailo-8L is optimized for edge-based computer vision tasks. Here’s what you can do with it:
  1. Computer Vision Tasks:
  • Object detection, image classification, and face recognition
  • Deploy pre-trained models from the Hailo Model Zoo or create custom models
  • Ideal for real-time video analytics, image processing, and similar applications
  • Excels at real-time inference on low-power devices (e.g., smart cameras, drones, IoT devices)
  1. Text-Based AI (NLP): The Hailo-8L isn’t designed for text-based AI tasks like Natural Language Processing (NLP). It’s built specifically for vision-based tasks, so it’s not suitable for running language models like GPT or BERT. These typically require more memory and processing power, often found in GPUs or cloud-based systems.
  2. Visual AI Applications: You can create visual AI applications with the Hailo-8L using real-time video feeds or images. It’s great for developing AI-powered systems like facial recognition, object tracking, or surveillance systems.
Let me know if you need more information or help getting started!
Best Regards,
Omri
I see, is this the case for this model or all your models can’t do what I said ?
Note: by creating an image I mean downloading and running the automatic1111 ai model
Yes for most models that is correct.
the Hailo-8L is optimized for vision-based AI tasks and isn’t suitable for running models like Automatic1111, which require more processing power. However, we have the upcoming Hailo-10H designed for generative AI, where models like Automatic1111 might work (though not tested yet). Small generative AI models have been tested on Hailo-8L, but for more complex tasks like text-to-image generation, the Hailo-10H will be a better fit once it is released soon.
thank you, it would be great if I could see the tests of that model, I know it is a very powerful model, it should be up to 40 tops. thanks for the information, it will be much better to buy this model
