Hi all,
I’m currently using a Raspberry Pi with the Hailo-8L and would like to experiment with YOLOv6.
From what I understand, it seems that YOLOv6 may not be supported within the pipeline example applications, and would instead need to be implemented using the standalone application approach.
Could anyone confirm if this is correct?
Also, are there any examples or recommended approaches for integrating YOLOv6 with Hailo on the Raspberry Pi?
Thanks in advance.
