Using mixed-mode (FP + QUANT) for network evaluation
When debugging loss of accuracy situation, in many cases, the majority of the loss is associated with only a few layers in the model. To test this, and idenity which are thos layers, we can use the “mixed-mode” operation of the emulator. Basically, we will emulate some layer(s) in full precision (32b) vs. optimized/quantized.
This is a basic code for doing so:
def network_mixed_eval(runner, target, image, native_layers, all_native=False):
    with runner.infer_context(target) as ctx:
        wrapped_keras_model_mixed = runner.get_keras_model(ctx)
        keras_model_mixed = wrapped_keras_model_mixed.layers[0]
        for lname, val in keras_model_mixed.layers.items():
            if all_native and 'postprocess' not in lname:
                keras_model_mixed.layers[lname].disable_lossy()
            elif lname.endswith(native_layers):
        result = keras_model_mixed(np.expand_dims(image, axis=0))
        return result
This is a proposed way for using that function. For rhis example, we’re going to use as simple 224x224 Mobilenet-v1 model.
First, we need to load a test image:
resized_image =  np.array(Image.open('000000000139.jpg').resize((224,224)))
Second, we need to have an optimized Mobilenet-v1 model, let’s load it into a runner:
runner = ClientRunner(har='mnv1.q.har')
The last part is the execution:
debug = network_mixed_eval(runner, InferenceContext.SDK_QUANTIZED, resized_image, ('conv13', 'conv14', 'fc1'))
For completeness, thos are the imports needed for all the above:
from PIL import Image
