USB Camera not working on Hailo-15H (Sensor Not Found)
Hi everyone,
I am working with Hailo-15H and trying to run the detection example using a USB camera instead of the default CSI cameras (like IMX678). But when i run the example i get this error : “Sensor not found”
From my understanding, the media library seems to be designed for specific CSI sensors and uses subdevice detection. Since USB cameras do not have subdevices, I think this might be the reason for the error.
1. Is it possible to use a USB camera with Hailo-15H?
  1. Do I need to change the input configuration JSON (like source type or format)?
  2. Should I use a different approach like appsrc to feed frames manually?
  3. Is there a recommended way to bypass sensor detection for USB cameras
And, in the examples, output is sent through UDP.
If I want to display the output on screen (Wayland display) instead:
  1. What changes are needed?
  2. Can I replace UDP with something like a display sink?
Any help or suggestions would be appreciated.
Thanks!
The Hailo Community currently supports our AI Accelerator products only.
For AI Vision Processors questions, please fill out the product inquiry form, and our team will get back to you shortly. Hailo AI Product Inquiry: Connect with Our AI Experts
