Hello
I created a new variant of yolo that i call yolov5n-zoom that is based on yolov5n network. I added kind of some attention modules on it. So I managed to generate an onnx from the export of the yolov5 hailo training docker file. But when I tried re compile I get this error
hailomz compile --ckpt ../shared_with_docker/yolov5n-zoom/best.onnx --calib-path ../shared_with_docker/dataset-v039/images/train/ --yaml hailo_model_zoo/hailo_mode
l_zoo/cfg/networks/yolov5n_zoom.yaml --classes 2 --hw-arch hailo8l
<Hailo Model Zoo INFO> Start run for network yolov5n_zoom ...
[info] Translation started on ONNX model yolov5n_zoom
[info] Restored ONNX model yolov5n_zoom (completion time: 00:00:00.05)
[info] Extracted ONNXRuntime meta-data for Hailo model (completion time: 00:00:00.38)
[info] Simplified ONNX model for a parsing retry attempt (completion time: 00:00:01.38)
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 220, in translate_onnx_model
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 300, in _parse_onnx_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 351, in parse_model_to_hn
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/translator.py", line 79, in convert_model
self._create_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 34, in _create_layers
self._add_direct_layers()
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 187, in _add_direct_layers
raise ParsingWithRecommendationException(
UnsupportedGatherLayerError in op Gather_166: Can't find index
UnsupportedGatherLayerError in op Gather_167: Can't find index
UnexpectedNodeError in op Unsqueeze_127: Unexpected node Unsqueeze_127 (Unsqueeze)
UnsupportedShuffleLayerError in op Transpose_168: Failed to determine type of layer to create in node Transpose_168
UnsupportedShuffleLayerError in op Reshape_169: Failed to determine type of layer to create in node Reshape_169
UnsupportedShuffleLayerError in op Reshape_174: Failed to determine type of layer to create in node Reshape_174
UnsupportedShuffleLayerError in op Reshape_181: Failed to determine type of layer to create in node Reshape_181
Please try to parse the model again, using these end node names: LeakyRelu_17, Pad_165, LeakyRelu_38, LeakyRelu_64, Add_142, Reshape_126
File "/local/workspace/hailo_virtualenv/bin/hailomz", line 33, in <module>
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 122, in main
run(args)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main.py", line 111, in run
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 250, in compile
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 73, in _ensure_optimized
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/main_driver.py", line 108, in _ensure_parsed
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/core/main_utils.py", line 97, in parse_model
model_name = translate_model(runner, network_info, ckpt_path, tensor_shapes=start_node_shapes)
File "/local/workspace/hailo_model_zoo/hailo_model_zoo/utils/parse_utils.py", line 28, in translate_model
runner.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_common/states/states.py", line 16, in wrapped_func
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/runner/client_runner.py", line 1158, in translate_onnx_model
parser.translate_onnx_model(
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/sdk_backend/parser/parser.py", line 260, in translate_onnx_model
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/edge_nn_translator.py", line 111, in _add_direct_layers
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 398, in _layer_callback_from_vertex
consumed_vertices = self._create_slice_layer(vertex)
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_translator.py", line 1610, in _create_slice_layer
h_slice, w_slice, f_slice, consumed_vertices = vertex.get_gather_slice_info()
File "/local/workspace/hailo_virtualenv/lib/python3.8/site-packages/hailo_sdk_client/model_translator/onnx_translator/onnx_graph.py", line 3470, in get_gather_slice_info
h_slice = [index[0], index[0] + 1] if single_dim else [index[0], index[1]]
TypeError: can only concatenate list (not "int") to list```
I believe he can't convert some ops. But if it is the case, is there any framework to add these ops in the hailo library?
Best
