I am going through the raspberrypi installation guide and am running into the below issue installing the hailo apps. As you can see, I already tried “apt update” and “apt full-update”. This is on otherwise a fresh install or bookworm 64-bit operating system.
Any idea whats going on? I am based in Buenos Aires, Argentina, if that matters for what deb packages I am finding through apt install.
Thank you!
user@raspberrypi1:~ $ sudo apt update && sudo apt full-upgrade && sudo apt install hailo-all
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
E: Unable to locate package hailo-all
